Carb number for a '66 R/T?
#1610749
04/22/14 09:28 PM
04/22/14 09:28 PM
Posts: 8,028 The Grand State of Confusion-O...
SKR8PN
Customer has a 66 Coronet R/T with a 440. Has a race AFB on it now that doesn't even come close to fitting properly and works even worse. He wants to find a rebuildable carb that will fit as far as kickdown linkage and throttle cable. What am I looking for? Carb number?
Karma has no menu. You get served what you deserve.
Re: Carb number for a '66 R/T?
[Re: BSB67]
#1610752
04/22/14 10:41 PM
04/22/14 10:41 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Again, if you want the correct number you'll need to figure out exactly what he has. There's nothing at all wrong with the CA carbs. As far as what will fit and look stock, here you go; Ebay 67 440 Carb
[Re: ScottSmith_Harms]
#1610753
04/22/14 11:06 PM
04/22/14 11:06 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Right. If that is what he is asking.
[Re: SKR8PN]
#1610757
04/25/14 12:08 PM
04/25/14 12:08 PM
RapidRobert
edelbrock Mopar throttle adapter #1481. $9.97 at Summitt. There's an AFB #4131S for $100 in the for sale section here which iirc is correct for a 66 HP 440. I have 2 of em (4131S) on a dual quad "B" single plane '58 iron intake going on a 451
[Re: BSB67]
#1610758
04/25/14 12:34 PM
04/25/14 12:34 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Technically speaking there was no "HP" 440 in 1966, just the "TNT" 440 for the Chrysler 300's etc. 1966's were a very different engine as compared to a 67 HP, smaller port heads, low rise intake, log style exhaust manifolds, etc. made the first year 440 basically nothing more than a bored out 413. The 4131 carb was the same one used on many of the mundane small valve head/LP 1966 383/413/440 engines, there was nothing "HP" about them in the least.
So, while the 4131 carb will work fine, a correct 67 carb (both being in stock form) will be a better unit more suited for a true 67 HP engine. An Edelbrock will also work fine but be sure to do a price check before just ordering a new carb, used originals rebuilt/restored are usually competitively priced and will always be worth more later if you decide to sell.
