tranny vibration after rebuild #1610746
04/22/14 09:28 PM
04/22/14 09:28 PM
Loveland CO
Jimbo Offline OP
Jimbo  Offline OP
Loveland CO
I just went through my basic overhaul of my 727, and when I got it back together, I have a vibration around 3500 rpm. It will vibrate in neutral and in gear, so I suspect the converter is out of balance for some reason. The converter is the same one that was in it before, and there wasn't a vibration before the rebuild.
Has anyone ever seen this before?
Re: tranny vibration after rebuild [Re: Jimbo] #1610747
04/22/14 09:43 PM
04/22/14 09:43 PM
not unless a weight fell off the TC. Not sure what could have moved/shifted. I'd wait for Kunkel to advise...
Re: tranny vibration after rebuild [Re: RapidRobert] #1610748
04/23/14 12:03 AM
04/23/14 12:03 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
I just had that last fall after a local shop rebuilt the 727 in my '67.
The second I drove it I knew something was not right. It wasn't a BAD vibration, but it definitely wasn't right. Did a U-turn right back to the shop and the mechanic who rebuilt my tranny hopped in for a ride and agreed.
They confirmed TC was improperly balanced. It was defective from their supplier. The shop said that simply happens once in a while and replaced it at no added cost.
Good luck,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
