Street Race a Stock 70 340 Duster vs 71 340 Duster #1610687
04/22/14 07:19 PM
04/22/14 07:19 PM
Phila Pa
scatpacktom Offline OP
Phila Pa
Both cars are equally shifted and geared, have about the same options and weigh within pounds of each other. Which car is faster and why?
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: scatpacktom] #1610688
04/22/14 07:41 PM
04/22/14 07:41 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Thermoquad puts the '71 first to the finish line.
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: B5 Bee] #1610689
04/22/14 07:55 PM
04/22/14 07:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
71, TQ AND Intake design.......But thats only if everyting is truely stock. Toss on a stealthy 800 cfm AVS, port the intake, etc. and the 70 might come out on top, of course the TQ car could then up the ante with a bigger TQ and ported intake as well. BTW, if anyone thinks the pass side exhaust manifold difference would give an edge to the sexier 70 design, I've dyno tested both, 1-2 hp difference, so basically nothing.
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: ScottSmith_Harms] #1610690
04/22/14 08:34 PM
04/22/14 08:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Assuming proper tuning the 71 has a bigger and technologically superior carb and matching bore manifold. I believe those are the only differences. 71 wins.
Doug
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: dvw] #1610691
04/22/14 11:29 PM
04/22/14 11:29 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
71, too bad no 6 pack option back then oh well..
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: scatpacktom] #1610692
04/23/14 12:19 AM
04/23/14 12:19 AM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
1971 wins, better stripes and sharktooth grill add 10HP
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: ademon] #1610693
04/23/14 12:19 AM
04/23/14 12:19 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Well there was......Sort of
*BTW, I got the chance to drive the car in this article, it was the tightest nicest Demon I ever drove and it was very fast for a stock 340 Six Pack.
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: ScottSmith_Harms] #1610694
04/23/14 12:21 AM
04/23/14 12:21 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I agree and was there in the day, Scott nailed it
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: ademon] #1610695
04/23/14 12:27 AM
04/23/14 12:27 AM
Phila Pa
Phila Pa
"BTW, if anyone thinks the pass side exhaust manifold difference would give an edge to the sexier 70 design, I've dyno tested both, 1-2 hp difference, so basically nothing."
I wouldn't have guessed that. The outlet is like 2.5 vs 1 7/8 plus the pipe diameter has the be smaller as well.
OK so we think 71 is king, how much better do we think a TQ is over a AVS? Take my Duster that has run a best of 13.20 how much faster is it if I were to swap out the intake and carb? A tenth? Two? If it is 5 to 10 hp it won't even show up on the strip.
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: scatpacktom] #1610696
04/23/14 12:33 AM
04/23/14 12:33 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Tom, only one way to find out for sure
In a real world test on the same car/engine I'd guess you wouldn't see a huge difference but on paper the 71 should be the winner (by whatever margin). It may come down to the individuals skills in carb tuning as well, AVS's are pretty basic/easy to tune, TQ's are a bit more complicated and need to be tuned properly to work at their peak, something that can take a bit of practice.
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: ScottSmith_Harms] #1610697
04/23/14 12:44 AM
04/23/14 12:44 AM
Phila Pa
Phila Pa
I know Scott
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: scatpacktom] #1610698
04/23/14 12:58 AM
04/23/14 12:58 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I know you know, so go do it man!
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: ScottSmith_Harms] #1610699
04/23/14 01:11 AM
04/23/14 01:11 AM
Phila Pa
Phila Pa
I had read that the hot lick back in the day was to put a 440 carb on a 340. I stuck a 69 440 carb on the Duster and took it for a spin. I didn't run it at the track but it seemed to do nothing. I put the correct carb right back on. I may have to revisit that test at the track. I remember I had to stack a couple of thick gaskets up so the throttle blades would clear the intake.
I know in Stock Eliminator the 71 car is clearly better than the 70. In stock form I'm just not sure. Doesn't seem to me a stock engine can use the TQ to its fullest potential. I keep thinking my car is second fiddle to a 71 but I'm just not really sure it is.
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: scatpacktom] #1610700
04/23/14 01:33 AM
04/23/14 01:33 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
When two cars are so closely matched it's really hard to prove either as superior. Running factory tires (i.e. traction issues) would probably make it even harder.
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: ScottSmith_Harms] #1610701
04/23/14 01:50 AM
04/23/14 01:50 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I would say the intake is the bigger plus more than the carb on the 71's. I really don't think you would see much difference on the time slip. The 71 aircleaner slowed my car down 2 tenths but my sb is more like 400hp.
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: ScottSmith_Harms] #1610702
04/23/14 03:34 AM
04/23/14 03:34 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Couple weeks away myself
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: ademon] #1610703
04/23/14 06:13 AM
04/23/14 06:13 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Hummmmmm, what should I pick? 70-71? 70-71? Ok, I'll go with the '71
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: bigblock340power] #1610704
04/23/14 03:54 PM
04/23/14 03:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
I remember watching the 1971 NHRA Winternationals stock qualifying in the classes the 340 ran in, the 1971 where quiet a bit faster than the 1970 cars in the same classes I didn't know at that time that the 1971 340 had different carbs than the 1970s did NHRA put the 1971 cars in the higher classes, weight per HP rules, later that year I beleive
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: ScottSmith_Harms] #1610705
04/23/14 10:44 PM
04/23/14 10:44 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Was there a compression ratio difference between 70&71?
Re: Street Race a Stock 70 340 Duster vs 71 340 Duster [Re: RV2] #1610706
04/23/14 10:55 PM
04/23/14 10:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I think some books state the 71's at 10.0 and the 70's at 10.5 comp ? I also dont remember if it was 71 or 72 when they started putting EGR jets in the bottom of the intake manifold ? Ron
