I know who to call, but... approximate cam specs?? #1610655
04/22/14 06:22 PM
04/22/14 06:22 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Hi all. I have a 493 shortblock that I plan to bolt 84cc edelbrock heads (out of the box) onto, along with a performer RPM intake (willing to change if needed), 950 CFM carb. The compression is 10.3:1 with the heads and .039” gasket. Small headers (1 5/8 schumachers, but I’ve seen people run 10.8 with them so I’m not considering them too bad of a handicap).
It will go into a ’67 Dart, minitubbed, automatic with 3800 stall converter, 3.91 gears.
I’m looking at solid flat tappet cams. I’d like to get something that sounds nice and lumpy at idle, and will still be torquey and have enough power to (theoretically) run ~10.6 or so in the 1/4 mile.
What approximate range of duration/lift and LSA would get me there?
Right now I’m looking at Lunati voodoo solid, but don’t know how nice it’ll sound in a 493. Yeah, I know sound aint everything, but if I can’t get on it all the time I at least want it to thump a bit.
Thanks for any input.
Below are the specs of the Lunati voodoo.
Solid Flat Tappet. Pro Street/bracket race cam with excel- lent mid range to high end torque and horsepower. Needs 3500 RPM stall converter, headers, 11:1+ compression ratio and 4.10+ gearing. Rough idle.
• Advertised Duration (Int/Exh): 288/296
• Duration @ .050 (Int/Exh): 259/267
• Gross Valve Lift (Int/Exh): .586/.606
• LSA/ICL: 110/106
• Valve Lash (Int/Exh): .016/.016
• RPM Range: 3000-7200
• Includes: Cam Only
Part Number: 30230743
Previous Part Number: 60343
Re: I know who to call, but... approximate cam specs?? [Re: Exit1965] #1610656
04/22/14 06:24 PM
04/22/14 06:24 PM
NE TN
straubtech Offline
straubtech  Offline
NE TN
500CID with a 1.625 header primary size. It it will be done at 4700 rpm. YOu will need to give the engine what it takes to breath sir....let it free!
Re: I know who to call, but... approximate cam specs?? [Re: Exit1965] #1610657
04/22/14 06:26 PM
04/22/14 06:26 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I would say 260-265ish @ .050, 110 LSA.
I would also say that 1 5/8 headers are too small for any RB Mopar, and way too small for that stroker. 1 7/8 at least on a 500 CID stroker. I didn't know anyone made them that small for big blocks.
Re: I know who to call, but... approximate cam specs?? [Re: Exit1965] #1610658
04/22/14 06:36 PM
04/22/14 06:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You want a low LSA.. something 108 or less.. I dont
know the flow rate of those OOTB heads but I would
think something in a .640 lift would be greater than
what the max flow lift is... you dont want a ton of
duration because it would dump your low end torque
but you want enough for a stroker
Re: I know who to call, but... approximate cam specs?? [Re: MR_P_BODY] #1610659
04/22/14 08:53 PM
04/22/14 08:53 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a solid flat tappet in my 63 and I had Dwayne Porter spec a cam for my combo. And I could not be happier as it works just like I wanted. I like some of a lumpy idle that makes good power. Ron
Re: I know who to call, but... approximate cam specs?? [Re: Exit1965] #1610660
04/22/14 10:18 PM
04/22/14 10:18 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
hi,
I put the smaller Voodoo cam 251/259@050 - 566/586 lift in a 2 different motors .
1st was my 440 , 68 Satellite , made 390/95 RWHP through a 5100 stall auto. Never ran before pulling it out . Very noisey tough sound through 3" pipes and hooker muffs . WAY Louder than the 509 hydraulic before it .
2nd was a 510 wedge(69 Roadrunner) , made 430 RWHP through a 4400 stall auto , went 11.18ish , 121-2MPH if I remember . Had TTI headers , Eddy heads prepped by Dwayne Porter originally I think . Car sounded great mostly due to the exhaust duration IMO .Customer didn't want any more cam .
Cant imagine the next size up being worse
Headers and head flow will be the biggest issues .
The 440 had maxed flow out , put cnc'd heads with different cam ( 258/258 540/540 lift) and gained 30+ RWHP
The 510 had hit max flow and you could not richen it up further - it did have a 6 pack with adjustable jetting plates on the outers
Both heads had stock intake port size
my
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: I know who to call, but... approximate cam specs?? [Re: Exit1965] #1610661
04/22/14 11:09 PM
04/22/14 11:09 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
With the 493 they will be a handicap, IMO No big cam for you. You need a smaller cam, like the MP 528 or similer that works well with a restricted exhaust.
Even with that said, you should still be able to run into the tens with a A-Body and your 10.3 comp. and 493 combo. I just wouldnt throw alot of cam at it.
EDIT; Dave, I just bumped up a post for you from 2013 in "Question and Answer" Its Titled , "Best headers for a street 440" Check out Skeptics link, "This Test" A comparison between 2" headers and the Schumacher tri,s. o a 451 and MP 590 cam.
Re: I know who to call, but... approximate cam specs?? [Re: Sport440] #1610662
04/23/14 11:40 AM
04/23/14 11:40 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Thanks. I've seen that article on Schumacher's site. And on Big block dart, a guy ran 10.7 with bigger headers then slowed to 10.90 with schumachers.
I'll probably upgrade to proparts soon, just want to get the motor in first, so I'm not restricting myself to the smaller headers it's just what i have now.
thanks for the suggestions everyone.
Re: I know who to call, but... approximate cam specs?? [Re: Exit1965] #1610663
04/23/14 03:20 PM
04/23/14 03:20 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Ill be the one who disagrees with the header size being a kill all. Are they ideal? No. Will they work ok? Yes.
Ask Squeeze. He is clickin off 10.60s with manifolds....
IDK what his cam profile is...but I assure you it is not close to a MP 528...
Ill bet its in the high 260s. Its all in the LSA with less than ideal exhaust (well that and who spec'd the grind)...Over 500 inches IIRC.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: I know who to call, but... approximate cam specs?? [Re: Exit1965] #1610664
04/23/14 03:34 PM
04/23/14 03:34 PM
• LSA/ICL: 110/106
Look at Comp Cams XS290S cam or if you want a bigger grind look at there XTQ286S-8 drag race cam grind
I'm a big fan of less duration, especially on street cars, with as much lift as you can run Install both of them with at least 4 degrees advance on the intake lobes
Re: I know who to call, but... approximate cam specs?? [Re: Exit1965] #1610665
04/23/14 04:01 PM
04/23/14 04:01 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
• LSA/ICL: 110/106
Remember that the cam specs is not for 500 cube so calulate whit a drop on power band by at least 500rpm ! I agree whit cab on less duration on a street car I run a 108 lobesep roller cam on mine whit just about same lift like yours but less duration and that is a monster on the street
