Re: cars in/on trailers
[Re: racerx]
#1610566
04/22/14 09:39 AM
04/22/14 09:39 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
If it's on the tires the shocks are already compressed to a point. I don't know anybody that ties their cars down so tight that the shocks are bottomed out.
[Re: racerx]
#1610567
04/22/14 10:06 AM
04/22/14 10:06 AM
Challenger 1
Cincinnati, Ohio
When storing your car in/on your trailers do you guys leave them tied down? Or do uall release the tie-downs to release the pressure on the shocks my thinking bout the shocks being compress like that will not be a good thing...........Thax.
I tie down the front K and the rear axle and let the suspension on the car being towed do it's thing. That way the straps are much less likely to come loose. So no it don't matter if the car is tied down as far as the shocks go. If you tie down the suspension then the trailer takes more of a beating and so does the car.IMO
[Re: racerx]
#1610568
04/22/14 11:18 AM
04/22/14 11:18 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I never keep it strapped down and I use to jack it up and put it on stands in the trailer... just to let the springs hang
[Re: Jeepmon]
#1610570
04/22/14 01:27 PM
04/22/14 01:27 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
If the suspension is working while its in or on the trailer its pretty much the same as driving it down the road. There is really no good way to tie the body down without having something under the car for it to set against(like a bladder that they use with dragsters).
68 Barracuda Formula S 340
[Re: Jeepmon]
#1610571
04/22/14 02:02 PM
04/22/14 02:02 PM
MR_P_BODY
I guess I'm the lazy one here.. when I drop off the trailer after a long day racing.. I dont even open the door to it, unless I have to.. That means I leave it all strapped down until I need to pull the car out next time..
Also, as a side note.. I'm pretty sure I read somewhere... I think it was the instructions for the Strange Strut set.. They recommend strapping the body down and not the chassis, as they dont want the suspension working while in travel..
In the trailer the suspension is working harder going down the highway than it is on the track... I use to put a air bag/bladder under the car in the trailer before I strapped it down(you dont want to pull the car down to bottom out the shocks/struts) but you dont want the suspension getting a major work out in the trailer... I got a hole in the air bag but I never replaced it and it did wear out the seals in my struts(along with the wheel stands)... the bag really helped a lot... also if I was going racing the next weekend I didnt bother to free up the straps but if more than a week I did pop the straps free but left them hooked up
[Re: MR_P_BODY]
#1610572
04/22/14 02:39 PM
04/22/14 02:39 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
When you guys leave the car in the trailer all the time do you take the weight off the trailer axles or just let the trailer springs sit with the load on them?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1610573
04/22/14 02:45 PM
04/22/14 02:45 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
It is far better to tie the car down by the frames so the suspension parts don't get wore out going to and from the races Let the trailer suspension do the work I make sure and inflate the rear slicks to 15 to 20 lbs before loading it for the trip to and back from the races
[Re: dragram440]
#1610574
04/22/14 02:48 PM
04/22/14 02:48 PM
MR_P_BODY
I have the rubber torsion style axles on the trailer and no I dont jack it up
[Re: MR_P_BODY]
#1610575
04/22/14 03:23 PM
04/22/14 03:23 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
mine set on the trailer all week and all winter strapped down..
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: Guitar Jones]
#1610577
04/22/14 08:52 PM
04/22/14 08:52 PM
Posts: 4,075 Mo.
racerx
Mo.
That's it the small amount of compression that's on the shocks that's being held by the tie-downs is what I'm concern with, don't really know of anyone that ties a racecar down to fully compress a shock
[Re: racerx]
#1610578
04/22/14 09:15 PM
04/22/14 09:15 PM
MR_P_BODY
I've known guys that did... they had bad angles where the tie down points were on the trailer(almost straight down)and they would pull the car down till it wouldnt move... when I showed them to move the mount points out farther that it would hold the car better fore and aft they moved them.. a lot of guys with short trailers tend to do this
[Re: racerx]
#1610579
04/22/14 10:14 PM
04/22/14 10:14 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
back to your question Quote:
Storing (static) the shocks with slight compression is far less of a concern then towing with the suspension in constant motion. Static compressed height causes no wear. When traveling down the road (in the trailer) or track, the shocks/springs are in motion. This motion causes heat from friction and spring torsional stresses (spring compression) that is where the "damage" happens to a shock/spring,next time you get to where you are towing your car reach under and touch the shocks - doesnt matter what type of trailer suspension you have, you'll have heat. The spring should not take a set while sitting, again heat is the culprit(no heat generation while sitting still). If they are, get new springs and possibily a new manufacturer. Every spring has only so many heat cycles in it, so the more often you race it and miles you tow it the more frequently you will have to replace the springs.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
