Dakota ECM Source #1610540
04/22/14 02:47 AM
04/22/14 02:47 AM
Missouri
NFURY8 Offline OP
super street
NFURY8  Offline OP
super street
Missouri
The ECM on my 97 Dakota is going bad, cutting out, hard starting and such. Getting an error code for Primary Coil Driver and local shop diagnosed as a bad ECM. They quoted me about $700 to replace. I found a couple sources online and even Amazon offering them for closer to $200. I know the VIN and mileage need flashed. Does anyone have any experience with buying an ECM replacement?
C-Body DryDock Bigger is Better!
Re: Dakota ECM Source [Re: NFURY8] #1610541
04/22/14 02:07 PM
04/22/14 02:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check around your area. I found a local place that sells them refurbished for $175 with VIN flash. Stay away from the ones done in Florida as they are not good.
