Fuel system question-is this enough? #1610494
04/22/14 12:27 AM
04/22/14 12:27 AM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
So I have a mild 440 with 8-71 blower and two 750 holleys.Can I feed this with a -8 line and a magnafuel 275 pump? I think I can but just wanted some other opinions.
Re: Fuel system question-is this enough? [Re: BEEQUIK] #1610495
04/22/14 12:43 AM
04/22/14 12:43 AM
Az
Crizila Offline
Crizila  Offline
Az
That pump wants a -10 in and out and a -8 bypass. So, -10 to the reg and -8 to the carbs.
Fastest 300
Re: Fuel system question-is this enough? [Re: Crizila] #1610496
04/22/14 12:50 AM
04/22/14 12:50 AM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
I have the chrome steel double pumper lines that are like 3/8 max. Do I still need the -10? Seems like a lot of fuel to just be squashed down like that. Or is it more about the available volume? Street strip car.
Re: Fuel system question-is this enough? [Re: BEEQUIK] #1610497
04/22/14 07:01 AM
04/22/14 07:01 AM
Az
Crizila Offline
Crizila  Offline
Az
You could probably get away with -6's ( two per carb) from the reg to the carbs. What are you looking at running for boost?
Fastest 300
Re: Fuel system question-is this enough? [Re: BEEQUIK] #1610498
04/22/14 02:51 PM
04/22/14 02:51 PM
Run the #8 to the fuel regulator and then individual #6 to each carbs. from the regulator, unless you want to use #8 to the carbs. The needle and seats will be the smallest retsrictor in the fuel supply lines that way BTW,DO NOT use a 10 micron fuel filter between the fuel pump and the fuel cell, gas tank supply lines(only 80 or largermicron size filters ) I learned that one the hard way :crazyme :Call or look at Magnafuels diagrams on line for plumbing thier pumps
Re: Fuel system question-is this enough? [Re: Cab_Burge] #1610499
04/22/14 04:00 PM
04/22/14 04:00 PM
Az
Crizila Offline
Crizila  Offline
Az
Good info!! I had magnafuel design mine. Pre filter = 74 micron. Post filter = 25 micron.
Fastest 300
Re: Fuel system question-is this enough? [Re: BEEQUIK] #1610500
04/22/14 04:10 PM
04/22/14 04:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm sure the -8 going forward is fine... but ALL
pumps like a larger supply side (inlet to the pump)..
remember that its atmospheric pressure pushing the
fuel into the pump... the pump builds the low pressure
for the fuel to be pushed in
Re: Fuel system question-is this enough? [Re: BEEQUIK] #1610501
04/22/14 11:59 PM
04/22/14 11:59 PM
According to Magnafuel
techs. thier 275 pump will feed up to 750 HP , the 300 pump will feed up to 900 HP I bought the 275 pump thinking I woud never make 750 HP, I now own a 300 and 500 pump The blower will make you greedy for more power and traction once you start driving the car Buy the bigger pump now, you won't be sorry later
Re: Fuel system question-is this enough? [Re: BEEQUIK] #1610502
04/23/14 11:56 AM
04/23/14 11:56 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I have a 300 QS Magna Fuel pump and filter combo for sale. 1 year old $400 + sh.
I went to the PS 500 for E-85.
Thanks, Don
Re: Fuel system question-is this enough? [Re: cudadon] #1610503
04/24/14 01:36 AM
04/24/14 01:36 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I went right to the 500 with filter.It will flow whatever you uneed .
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
