Re: Hooking up tach, best place to tie into dash lighting?
[Re: FastOrange]
#161040
12/04/08 11:42 AM
12/04/08 11:42 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
If you look at the dash harness, there should be some wire molds that have 3 female sockets. Some are power, some are ground. If there is a free spot, a "bullet" connector available at the auto parts store should fit (there are different sizes) This should eliminate tapping into the harness. I believe this is how the factory powered the various options (like light group) A copy of the wiring diagrams should be available here: http://www.mymopar.com/index.php?pid=24hope this helps
Common sense is a flower that does not grow in everybody's garden
[Re: Ron_M]
#161041
12/04/08 12:01 PM
12/04/08 12:01 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
Just hook it to the dash light fuse, it'll work with the headlight switch .
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: FastOrange]
#161045
12/04/08 07:26 PM
12/04/08 07:26 PM
Posts: 5,161 CT
GTX MATT
CT
I used the radio for power to the tach itself
[Re: farmington]
#161046
12/05/08 01:59 AM
12/05/08 01:59 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Usually the light system wires under the dash are orange. Just tap into one.
There will be a couple of Orange 3-way molds in the dash wiring....one should be around the ash tray area with two wires in it already. I don't think they dim with the dash rheostat...they supply a constant power when the headlite switch is turned on to either park or head lite positions.
[Re: superwrench]
#161047
12/05/08 12:40 PM
12/05/08 12:40 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
and they do dim, at least on my car. I run all my aftermarket guage lights off it and they work exactly as the factory guage lights.
