Hooking up tach, best place to tie into dash lighting? #161038
12/04/08 11:25 AM
12/04/08 11:25 AM
Houston, Texas
FastOrange Offline OP
Houston, Texas
I'm hooking up a pro comp 5" tach. I need to get power to the tach lighting and also power the tach itself. I want to tie the tach lighting into the rest of the dash lighting so the tach will be illuminated along with the rest of the dash. So I don't just want a switched 12V source not tied into the dash lights. Any ideas?
Re: Hooking up tach, best place to tie into dash lighting? [Re: FastOrange] #161039
12/04/08 11:28 AM
12/04/08 11:28 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I usually dig out the radio leads.
Ride eternal, shiny and chrome
Re: Hooking up tach, best place to tie into dash lighting? [Re: FastOrange] #161040
12/04/08 11:42 AM
12/04/08 11:42 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
If you look at the dash harness, there should be some wire molds that have 3 female sockets. Some are power, some are ground. If there is a free spot, a "bullet" connector available at the auto parts store should fit (there are different sizes)
This should eliminate tapping into the harness. I believe this is how the factory powered the various options (like light group)
A copy of the wiring diagrams should be available here:
http://www.mymopar.com/index.php?pid=24
hope this helps
Common sense is a flower that does not grow in everybody's garden
Re: Hooking up tach, best place to tie into dash lighting? [Re: Ron_M] #161041
12/04/08 12:01 PM
12/04/08 12:01 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Just hook it to the dash light fuse, it'll work with the headlight switch .
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Hooking up tach, best place to tie into dash lighting? [Re: 70dart360] #161042
12/04/08 01:32 PM
12/04/08 01:32 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
Usually the light system wires under the dash are orange. Just tap into one.
Re: Hooking up tach, best place to tie into dash lighting? [Re: FastOrange] #161043
12/04/08 01:43 PM
12/04/08 01:43 PM
IMGTX Offline
IMGTX  Offline
What kind of car?
On my Challenger there is a three bullet female connector that is orange in color that is rarely used. I just stuck a bullet in that one and I was good to go. There are sometimes more than one but mine was to the right of the instrument cluster under the dash. They are used for optional stuff like Ashtray lights etc.
Re: Hooking up tach, best place to tie into dash lighting? [Re: IMGTX] #161044
12/04/08 05:52 PM
12/04/08 05:52 PM
Houston, Texas
Houston, Texas
70 Challenger SE. Thanks for the posts. Those schematics are cool.
I have all kinds of options available for hooking this up. Thanks again for the help.
Re: Hooking up tach, best place to tie into dash lighting? [Re: FastOrange] #161045
12/04/08 07:26 PM
12/04/08 07:26 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I used the radio for power to the tach itself
Re: Hooking up tach, best place to tie into dash lighting? [Re: farmington] #161046
12/05/08 01:59 AM
12/05/08 01:59 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
There will be a couple of Orange 3-way molds in the dash wiring....one should be around the ash tray area with two wires in it already.
I don't think they dim with the dash rheostat...they supply a constant power when the headlite switch is turned on to either park or head lite positions.
Re: Hooking up tach, best place to tie into dash lighting? [Re: superwrench] #161047
12/05/08 12:40 PM
12/05/08 12:40 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
and they do dim, at least on my car. I run all my aftermarket guage lights off it and they work exactly as the factory guage lights.
Re: Hooking up tach, best place to tie into dash lighting? [Re: challenger70] #161048
12/05/08 03:32 PM
12/05/08 03:32 PM
scratchnfotraction Offline
I have found the orange 3-plug to dim with the dimmer
and a blue wire with a red 3-plug and it was 12volt with the key and did not dim
