Morel hyd rollers source #1610476
04/22/14 12:21 AM
04/22/14 12:21 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Where do you guys get em from? Direct or a supplier? Im after a set for a street/sometime strip Hemi
I assume its better to run the ones with the bigger roller as below? Would this below be suitable ?
http://johncalliesinc.com/product.php?ProductNo=6073
Some don't like hyd rollers due to the Hemis valvetrain weight but if I use the right lifter/spring up to 6500 MAX it should be OK yes/no?
Cam will likely be @ 240-250 dur @ .050 max with around mid .550 - .570" of lift.
Thoughts ?
Re: Morel hyd rollers source [Re: LAD 524] #1610477
04/22/14 12:49 AM
04/22/14 12:49 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Call Straub Technologies, they'll set you up with the correct Morel lifters.
Re: Morel hyd rollers source [Re: LAD 524] #1610478
04/22/14 01:15 AM
04/22/14 01:15 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Erson cams. they sell them under the PBM name.
Re: Morel hyd rollers source [Re: mopar dave] #1610479
04/22/14 10:24 AM
04/22/14 10:24 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Doug Herberts "House Brand" HR's and solids are made by Morel
WIZE
In Car:
Re: Morel hyd rollers source [Re: LAD 524] #1610480
04/22/14 11:48 AM
04/22/14 11:48 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Im a Morel dealer, and stock some of them. Shoot me a PM with all your info, and what your looking for exactly, and all the car/engine specs. We'll see what you need that way.
Thank you
RIP Monte Smith
Re: Morel hyd rollers source [Re: CompWedgeEngines] #1610481
04/22/14 02:43 PM
04/22/14 02:43 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Thank you
Didn't know that, you'll get the call next time.
Re: Morel hyd rollers source [Re: LAD 524] #1610482
04/22/14 06:37 PM
04/22/14 06:37 PM
NE TN
straubtech Offline
straubtech  Offline
NE TN
Morel has a couple of series of lifters for the Mopars. The street series is recommneded up to .375" lobe lift. This is for the guys wanting some weekend power and occasional blast down the track.
This is a cast OEM type body with a .700" wheel.
The pro series will take just about anything you throw at it. These lifters have a .810" tool steel wheel and axle, tool steel body, and feature pressure fed oiling to the needles. They will take more spring pressure than most will ever see and they will turn over 8000 rpm in a properly set up valvetrain.
We just had a 532 CID brand "C" engine make over 800HP on pump gas with a set of these to 7600 rpm.
Re: Morel hyd rollers source [Re: straubtech] #1610483
04/23/14 12:37 PM
04/23/14 12:37 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Good info for sure....
Im wondering if you have run the HP hyd rollers in a big inch street/strip Hemi and what did you find/learn ? Or even in engines that traditionally have valvetrain issues?
Some say that the Hemi's valvetrain is too heavy and the pushrod angles/pushrod seat in the hyd roller make it an unstable valvetrain not able to rpm easily.
Care to share?
Re: Morel hyd rollers source [Re: LAD 524] #1610484
04/23/14 05:14 PM
04/23/14 05:14 PM
NE TN
straubtech Offline
straubtech  Offline
NE TN
Care to share?
Most of the stuff I do is BBC, but some of that is .371" stem stuff and it is heavy. Morel does use the same body on the high rpm stuff for Chevy/Ford/Mopar. In more than not the Mopar block will need to be bushed for it to work. The street stuff is just fine.
The .903" pro series lifter will benefit from a shorter pushrod due to the tall seat location in the lifter.
Most of the Mopar stuff I have cammed has been solid roller stuff.
