trying to get my 69 charger project running reliably and having all kinds of trouble with my keisler...
it seems to be that the clutch is not working properly...those that know a lot more than me feel that there is air in the system and they tell me that thre is no bleeder valve in the keisler configuration.
basically if I start out and the car is shifting okay, when it gets hot,it becomes harder and harder to shift..to the point where I can get it gear at all and have to force it in with the car shut off..
really frustrating and baffling the experts that help me..
one guy who is really and expert on this type of stuff, but not the keisler set up things that possibly the synthetic oil we used for the clutch is heating up too much and getting bubbles in it which is then causing the air in the system which then makes the clutch inoperable..
any one have similar problems? anyone have any ideas..
we are going to try and keep the clutch reservoir cap loose and also considering putting regular brake fluid in the clutch system.
thanks for any and all comments
