rod bearing failure what the....? #1610008
04/20/14 08:38 PM
04/20/14 08:38 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
while stripping down my block so i can do some pressure tests, i found 2 rod bearings having a rather unusual failure. well one i'd never seen anyway. at first i thought they had fused onto the crank journal because they fought me hard when i tried to get them off. once off it became apparent they were no longer the same shape as the others. they where a tighter radius as well as being toast. they're the same part # as the others but they physically look like they were for a smaller journal. what would cause this?
Re: rod bearing failure what the....? [Re: rebel] #1610009
04/20/14 08:39 PM
04/20/14 08:39 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
compared to another bearing they're a tighter radius for sure.
Re: rod bearing failure what the....? [Re: rebel] #1610010
04/20/14 08:51 PM
04/20/14 08:51 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
That really looks like a piece of metal shaving or a piece of sand grit got into your oil supply. Something too big to pass thru and the grit ate the bearing up and pulled on it enough to re shape the bearing. Seen it before. Clean everything thoroughly and put new bearings n it.
Old Geezer Racing
Re: rod bearing failure what the....? [Re: rebel] #1610011
04/20/14 08:57 PM
04/20/14 08:57 PM
Az
Crizila Offline
Crizila  Offline
Az
Look at the discoloration on the back of the bearing. It got hot enough to loose it's tension / shape.
Fastest 300
Re: rod bearing failure what the....? [Re: rebel] #1610012
04/20/14 08:58 PM
04/20/14 08:58 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
heat from the lack of oil/clearance
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: rod bearing failure what the....? [Re: bigtimeauto] #1610013
04/21/14 12:55 AM
04/21/14 12:55 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
EXACTLY........did you check the bearing clearances on EVERY rod and EVERY throw, or just put them in. You were VERY few runs from a spun bearing and a wiped crank journal. Be sure and have those rods checked for roundness, size and proper crush, as well as checking the crank for size and taper
Monte
Re: rod bearing failure what the....? [Re: Monte_Smith] #1610014
04/21/14 02:03 AM
04/21/14 02:03 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
i bought this engine complete as a fresh build from a member on here, it was built by Robinson Engines in Middletown Ohio. i assumed it was professionally built so only checked the named parts were installed & fitted the engine into my car. this time round i'm checking everything myself.
Re: rod bearing failure what the....? [Re: rebel] #1610015
04/21/14 02:58 PM
04/21/14 02:58 PM
No ones cares more about you than you and your love ones, do all you can yourself I had a older comercial pilot tell me yeas ago he made sure on every flight he was involved in that he didn't let anyone else kill him do to there incompetence or lack of skill I try to use the rule now also
Re: rod bearing failure what the....? [Re: Cab_Burge] #1610016
04/21/14 04:23 PM
04/21/14 04:23 PM
Az
Crizila Offline
Crizila  Offline
Az
Excellent info. My brother was big in to aerobatic flying ( owned a Citabria ) a few years back. Had his first annual done on the plane. Taxied to the end of the runway and lined up for take-off. Went to test both mags. Shut one off and the motor died. The guy that did the inspection forgot to hook up the wire to 1 of the mags. It wasn't 6 months before my brother got his own A&P license and was qualified to do his own annuals - including twin motored stuff. Moral, do it yourself if you can.
Fastest 300
Re: rod bearing failure what the....? [Re: Crizila] #1610017
04/22/14 12:52 AM
04/22/14 12:52 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
ANY engine, that is of a performance intent.....if I didn't assemble it myself, or know the builder VERY well, I consider that engine used and I knock it down to have a look. And I have seen some well known BUILDERS who may mic the crank and rods, but pull ONE PAIR of bearings from a set to check clearance and then just assemble the rest. Anything could happen, from a thin or thick shell, to packaged wrong, or stamped wrong. CHECK THEM ALL. Sure, it takes time, but less time than redoing a motor because of a spun bearing
Monte
Re: rod bearing failure what the....? [Re: Monte_Smith] #1610018
04/22/14 10:20 AM
04/22/14 10:20 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
While you are at it check your cam bearings.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: rod bearing failure what the....? [Re: rebel] #1610019
04/22/14 11:59 AM
04/22/14 11:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its heat causing that... I had low oil pressure in
a Jeep I bought so I dropped the pan and seen 1 set
of rod bearings that fell out ... I replaced them
with a stock set of bearings and changed the oil pump...
I believe the previous owner ran low on oil or over
heated the engine
Re: rod bearing failure what the....? [Re: Monte_Smith] #1610020
04/22/14 08:41 PM
04/22/14 08:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Monte
A saying I learned long ago. If you didn't have enough time to check the first time, you'll certainly have enough time the second time. Its always quicker to do it once.
Doug
Re: rod bearing failure what the....? [Re: dvw] #1610021
04/22/14 10:50 PM
04/22/14 10:50 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
it's a bit like buying a Crate motor. would you still pull it down & check everything? this engine came to me as a fresh build wrapped in cling wrap plastic. it was meerly a case of pull the pan, check the bearings were new & the parts were what it was advertised as. unfortunately for us now we've found there was dirt inside the galleries as all the bearings show contamination. but when all the holes are plugged i kinda expected the engine to have been built to some degree of expertise. live & learn i guess, trust nobody, no matter how highly they're regarded. looks like i'm the best engine builder i know & thats' scarey!
Re: rod bearing failure what the....? [Re: rebel] #1610022
04/23/14 01:05 AM
04/23/14 01:05 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm not the best engine builder I know.................but I'm the only engine builder I trust.
Sorry about your troubles.
Re: rod bearing failure what the....? [Re: rebel] #1610023
04/23/14 10:35 AM
04/23/14 10:35 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes I did. I bought a Mopar Performance crate hemi and it's a good thing I tore it down , what a mess ...
Re: rod bearing failure what the....? [Re: JohnRR] #1610024
04/23/14 11:47 AM
04/23/14 11:47 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
2011 Drag Pak Challenger
Re: rod bearing failure what the....? [Re: rickseeman] #1610025
04/23/14 06:49 PM
04/23/14 06:49 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Good bearing info
http://catalog.mahleclevite.com/bearing/
thanx for that link, good to know these things.
Re: rod bearing failure what the....? [Re: rebel] #1610026
04/24/14 12:22 AM
04/24/14 12:22 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
"Crate Motors" are seldom assembled by the most experienced builder in most shops. There is a big difference in a "builder" and an "assembler". ANY reasonably competent person can "assemble" a motor.
Monte
