Re: rod bearing failure what the....?
[Re: rebel]
#1610010
04/20/14 08:51 PM
04/20/14 08:51 PM
Posts: 1,505 TN
SCATPACK 1
TN
That really looks like a piece of metal shaving or a piece of sand grit got into your oil supply. Something too big to pass thru and the grit ate the bearing up and pulled on it enough to re shape the bearing. Seen it before. Clean everything thoroughly and put new bearings n it.
Old Geezer Racing
[Re: bigtimeauto]
#1610013
04/21/14 12:55 AM
04/21/14 12:55 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
. once off it became apparent they were no longer the same shape as the others. they where a tighter radius as well as being toast. they're the same part # as the others but they physically look like they were for a smaller journal. what would cause this?
heat from the lack of oil/clearance
EXACTLY........did you check the bearing clearances on EVERY rod and EVERY throw, or just put them in. You were VERY few runs from a spun bearing and a wiped crank journal. Be sure and have those rods checked for roundness, size and proper crush, as well as checking the crank for size and taper
Monte
[Re: Crizila]
#1610017
04/22/14 12:52 AM
04/22/14 12:52 AM
Monte_Smith
North Alabama
ANY engine, that is of a performance intent.....if I didn't assemble it myself, or know the builder VERY well, I consider that engine used and I knock it down to have a look. And I have seen some well known BUILDERS who may mic the crank and rods, but pull ONE PAIR of bearings from a set to check clearance and then just assemble the rest. Anything could happen, from a thin or thick shell, to packaged wrong, or stamped wrong. CHECK THEM ALL. Sure, it takes time, but less time than redoing a motor because of a spun bearing
Monte
[Re: rebel]
#1610019
04/22/14 11:59 AM
04/22/14 11:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Its heat causing that... I had low oil pressure in a Jeep I bought so I dropped the pan and seen 1 set of rod bearings that fell out ... I replaced them with a stock set of bearings and changed the oil pump... I believe the previous owner ran low on oil or over heated the engine
[Re: Monte_Smith]
#1610020
04/22/14 08:41 PM
04/22/14 08:41 PM
Posts: 9,847 MI, usa
dvw
MI, usa
Monte
A saying I learned long ago. If you didn't have enough time to check the first time, you'll certainly have enough time the second time. Its always quicker to do it once. Doug
[Re: rebel]
#1610022
04/23/14 01:05 AM
04/23/14 01:05 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
looks like i'm the best engine builder i know & thats' scarey!
I'm not the best engine builder I know.................but I'm the only engine builder I trust.
Sorry about your troubles.
[Re: rebel]
#1610023
04/23/14 10:35 AM
04/23/14 10:35 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
it's a bit like buying a Crate motor. would you still pull it down & check everything?
Yes I did. I bought a Mopar Performance crate hemi and it's a good thing I tore it down , what a mess ...
