1969 roadrunner rear tire size #1609474
04/19/14 05:35 PM
04/19/14 05:35 PM
Iowa
beaver77 Offline OP
beaver77  Offline OP
Iowa
What size rear tire can I get on a 69 roadrunner. Looks like with a 4.25 or 4.50 backspace wheel I might be able to get a 275-60-15. Just looking for guidance from some who has done this.
Re: 1969 roadrunner rear tire size [Re: beaver77] #1609475
04/19/14 06:09 PM
04/19/14 06:09 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
My dad run's that exact tire on the back of his 69. Not sure of the back spacing, I'll try to ask him.
1972 Road Runner
1988 Shelby CSX-T
Re: 1969 roadrunner rear tire size [Re: beaver77] #1609476
04/19/14 07:55 PM
04/19/14 07:55 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I'm running that size Hoosier Drag Radials on my Satellite. I'm running a 10 inch wheel but I have closer to a 5-1/2 to 6 inch backspace.... Hard to tell when it's on the on the car thought...
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: 1969 roadrunner rear tire size [Re: QTR MILR] #1609477
04/19/14 09:13 PM
04/19/14 09:13 PM
6T9RR Offline
6T9RR  Offline
I'm running 275 - 60 -15's on 15x7 wheels on the back. It's all stock no mods & they fit fine.
Re: 1969 roadrunner rear tire size [Re: 6T9RR] #1609478
04/19/14 10:59 PM
04/19/14 10:59 PM
Bad Axe,MI
E
EDDIEB Offline
EDDIEB  Offline
E
Bad Axe,MI
I run N-50's on mine with a 10 in rim
Re: 1969 roadrunner rear tire size [Re: beaver77] #1609479
04/20/14 09:43 AM
04/20/14 09:43 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
275 60-15's work great on Runners, Bees, and Chargers.
I run 225 70-15's in front with them. Similar height.
7 inch rim in front, 8 inch rim in back. Standard back spacing
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: 1969 roadrunner rear tire size [Re: Kowal] #1609480
04/21/14 06:18 AM
04/21/14 06:18 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
HELLO I HAVE TWO ROAD RUNNERS AND BOTH HAVE 15X8 RIMS ON THE REAR WITH A 5" BACKING ALSO RUNING A 275X60X15 ON REAR 225X70X15 ON THE FRONT . WORKS GREAT AN LOOKS GREAT ! A REAL MOPAR MAN !!
Re: 1969 roadrunner rear tire size [Re: mosweethemi] #1609481
04/22/14 04:35 AM
04/22/14 04:35 AM
Oh
His and Her 69's Offline
Oh
I have the standard off set 15 x 8 cragars on mine and the tires are
28 x 12.50 x 15 ET street tires. They fit Great!!!
No rubbing or not even close.
David
Re: 1969 roadrunner rear tire size [Re: His and Her 69's] #1609482
04/22/14 02:59 PM
04/22/14 02:59 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
275-60-17's on 9.5" wheel with 5.5" backspace is what I have on my 70.
...FAFO...
Re: 1969 roadrunner rear tire size [Re: skicker] #1609483
04/25/14 12:46 PM
04/25/14 12:46 PM
an8sec70cuda Offline
15x8 rim w/ 4.5" of back spacing and a 275-60 tire on my dad's '69 road runner.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1969 roadrunner rear tire size [Re: an8sec70cuda] #1609484
04/25/14 06:57 PM
04/25/14 06:57 PM
Washington PA
69 plymouth rnr Offline
Washington PA
Steel rims from summit 15x8 4.5 back spacing 295 65 15 !!!
BIG and TIGHT but works
1969 rr
Re: 1969 roadrunner rear tire size [Re: 69 plymouth rnr] #1609485
04/27/14 02:36 PM
04/27/14 02:36 PM
minnesota
Y
yevntri Offline
yevntri  Offline
Y
minnesota
Would you have any pictures of the 295x65x15, Also what brand of tire are they..I"M running 275x60x15 and would like to go with a larger tire.
