How to test gauges out of the car? #160927
12/03/08 10:16 PM
12/03/08 10:16 PM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
How do you test the oil pressure, water temp, and alt. gauges. I bought a second rallye dash and i want to see if the guages work, and are accurate...
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: How to test gauges out of the car? [Re: 340wedge] #160928
12/03/08 10:19 PM
12/03/08 10:19 PM
Andrewh Offline
Andrewh  Offline
wire up 2 aa batteries in series so they give 3 volts.
Then connect them up to the gauage. should put it in the middle.
Gauges get 5 volts. Don't use a car battery or you could smoke them.
Re: How to test gauges out of the car? [Re: 340wedge] #160929
12/03/08 10:19 PM
12/03/08 10:19 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Basically you build the whole circut on the bench, then each gauge can be fine tuned with the trim adjustments on the back of the gauge...
10 Ohms = High reading
73 Ohms = Low reading
Re: How to test gauges out of the car? [Re: 1_WILD_RT] #160930
12/03/08 11:25 PM
12/03/08 11:25 PM
340wedge Offline OP
340wedge  Offline OP
OK I kinda understand with an Ohm meter, but how do i do this and what should the reading be? Are they the same for each type gauge?
Re: How to test gauges out of the car? [Re: 340wedge] #160931
12/03/08 11:35 PM
12/03/08 11:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not an Ohm meter resistors to act as the sending unit, Fuel, oil & temp all use the same resistance values for high & low readings... Ammeter doesn't fit this test very well... you can pass current through it & compare the results to a known calibrated gauge...
Re: How to test gauges out of the car? [Re: 1_WILD_RT] #160932
12/03/08 11:52 PM
12/03/08 11:52 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Re: How to test gauges out of the car? [Re: Pool Fixer] #160933
12/09/08 10:01 PM
12/09/08 10:01 PM
Arkansas
GregGarner Offline
GregGarner  Offline
Arkansas
We also have some info on our website:
http://rt-eng.com/mediawiki/index.php/RT..._vintage_mopars
GregGarner
www.rt-eng.com
Home of the mopar solid state limiter adn tach repair kit
