Guys running efi, what are you using for a fuel pump? #1609185
04/18/14 11:18 PM
04/18/14 11:18 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
Since the 413 has decided it wanted to get pulled out of the 62 New Yorker, we may well put a new Hemi or mag 5.9 in the old ride. One of my biggest concerns is what to use as a fuel pump. The 62s gas tank is long, skinny and fairly flat, it about 6"-8" high, and has a fuel gauge about 2 1/2" in diameter. I don't think a newer fuel pump will fit very well in the 62s original tank, and there also is no provision for a return line into the tank at all.
What are you guys that are using the newer EFI doing? Gene
Re: Guys running efi, what are you using for a fuel pump? [Re: poorboy] #1609186
04/19/14 01:02 PM
04/19/14 01:02 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I know this isn't the answer you are looking for. I used the OEM fuel pump in my Gen 3 installation. Since I have a PU I simply mounted an 04 Dakota tank in the bed of my truck and installed the fuel pump from the 03 RAM that donated the Hemi. However, this may be a viable option for your installation.
http://aeromotiveinc.com/2012/11/phantom-fuel-system/
Re: Guys running efi, what are you using for a fuel pump? [Re: Dabee] #1609187
04/25/14 12:23 AM
04/25/14 12:23 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
A couple of options both using an external EFI pump. External pumps work best with flooded suction.
First option is get a sump kit from Summit or Jegs and weld it into your stock tank and use the original pick up tube for your return.
Option 2 would be a fuel cell in the trunk.
I used option #2 on my 66 New Yorker because the original tank was rough and a fuel cell was cheaper than a new replacement and it solved the return line dilemma.
Kevin
Re: Guys running efi, what are you using for a fuel pump? [Re: Twostick] #1609188
05/09/14 01:43 PM
05/09/14 01:43 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
No first hand experience with this, but this is new from Edelbrock and looks like a nice option:
You mount this wherever you have the room.
Re: Guys running efi, what are you using for a fuel pump? [Re: PolyDart] #1609189
05/09/14 02:08 PM
05/09/14 02:08 PM
dogdays Offline
dogdays  Offline
And it is filled by the engine's mechanical fuel pump.
It's the kind of idea that I wish I'd had first!
R.
Re: Guys running efi, what are you using for a fuel pump? [Re: dogdays] #1609190
05/09/14 06:48 PM
05/09/14 06:48 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
Do you have a link where I can have a good look at that? Gene
Re: Guys running efi, what are you using for a fuel pump? [Re: poorboy] #1609191
05/10/14 01:59 AM
05/10/14 01:59 AM
san diego
JonsGottaDusta Offline
san diego
We have a Walbro GLS392 255LPH pump in a custom built fuel cell that's feeding a supercharged 289 in my dad's Falcon. If you're going stock it may be overkill, but they're dirt cheap and I've had great luck with them.
Re: Guys running efi, what are you using for a fuel pump? [Re: PolyDart] #1609192
05/10/14 05:18 PM
05/10/14 05:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did similar back in the 90's when I put EFI on my Diplomat. Ebrock wants a fortune for it. You can fab it up yourself out of metal for a lot less. I used my engine's mechanical pump o fill the reservoir, with the EFI pump (inline) being fed by the sump, had an overflow/vent back to the tank. Heck, you could probably make it out of 2" black/galvanized pipe if you don't weld.
Don't be the exception.
Re: Guys running efi, what are you using for a fuel pump? [Re: Supercuda] #1609193
06/17/14 12:45 PM
06/17/14 12:45 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
you want the reservoir to at least hold a quart of fluid if not more. also your fuel rail return line should be connected here as well.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
