8.75 ... 489 ... what year? #1608873
04/18/14 01:26 AM
04/18/14 01:26 AM
SD
Z
zrxkawboy Offline OP
Z
SD
I recently purchased an 8.75 rear out of a '66 Charger. However, it is a 489. From what I can find, these started production in '69. Since it was in (fit) the '66, I'm assuming this must have originally been in a '69 or '70 B-body. Is that right?
It's Swifty! Swifty, you toad sucker!
Re: 8.75 ... 489 ... what year? [Re: zrxkawboy] #1608874
04/18/14 01:40 AM
04/18/14 01:40 AM
I would assume it came from a mid 68 something (when the 489 intro'd) & since it has been changed out it would not have neccessarily have come from a B body
Re: 8.75 ... 489 ... what year? [Re: RapidRobert] #1608875
04/18/14 01:49 AM
04/18/14 01:49 AM
SD
Z
Z
SD
OK, I just thought that the distance between the perches changed for 71-74. That's why I thought it must be 69-70. So that's not right?
Edit: One of the posts I was referencing disappeared after I posted!
Re: 8.75 ... 489 ... what year? [Re: RapidRobert] #1608876
04/18/14 01:50 AM
04/18/14 01:50 AM
dogdays Offline
dogdays  Offline
Unless they were running short of 741 cases at some point, I would venture to guess that the 489 probably came behind a HP383, HP400 or any 440. Maybe 340s, maybe not every year's 340.
This is mostly a guess, but there are a lot of 741s out there, same as there are a lot of 318s and slant sixes. I've never seen one (489) behind a 318, although again, Mopar, never say never!
I'm sure someone else will clarify things.
R.
Re: 8.75 ... 489 ... what year? [Re: dogdays] #1608877
04/18/14 01:53 AM
04/18/14 01:53 AM
Kirkland, Washington
Pacnorthcuda Offline
Lots of 489's were paired with 318's. Your center section may not be original to the housing, that's what makes things very hard to determine.
Re: 8.75 ... 489 ... what year? [Re: zrxkawboy] #1608878
04/18/14 03:54 AM
04/18/14 03:54 AM
I'm almost positive your correct on the 489 cases being introduce into the production cars in mid 1969
Re: 8.75 ... 489 ... what year? [Re: Pacnorthcuda] #1608879
04/18/14 10:09 AM
04/18/14 10:09 AM
SD
Z
Z
SD
Thanks, everyone, for the replies.
True...I hadn't considered that the housing may have been original to the car. I guess it doesn't matter much, just more of a curiosity thing.
Re: 8.75 ... 489 ... what year? [Re: Cab_Burge] #1608880
04/18/14 01:32 PM
04/18/14 01:32 PM
Oh OK mid 69 not mid 68,
Re: 8.75 ... 489 ... what year? [Re: RapidRobert] #1608881
04/18/14 03:17 PM
04/18/14 03:17 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Nope you were right the first time...the 489 was introduced during the 68 model year.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 8.75 ... 489 ... what year? [Re: 69CoronetRT] #1608882
04/18/14 05:12 PM
04/18/14 05:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: 8.75 ... 489 ... what year? [Re: TJP] #1608883
04/18/14 05:16 PM
04/18/14 05:16 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
what's the date stamped on the ring gear?
Re: 8.75 ... 489 ... what year? [Re: 69CoronetRT] #1608884
04/18/14 06:57 PM
04/18/14 06:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory parts book says January 9, 1968 was the introduction date for the 489 in some models and some ratios (2.76, 3.234 and 3.55 only).
Re: 8.75 ... 489 ... what year? [Re: John_Kunkel] #1608885
04/18/14 07:31 PM
04/18/14 07:31 PM
Did early 489's come with power locks?
Re: 8.75 ... 489 ... what year? [Re: Pacnorthcuda] #1608886
04/18/14 08:44 PM
04/18/14 08:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Apparently not...the parts book shows a new number for the open differential when used on the 1 7/8" but not the Sure-Grip.
Re: 8.75 ... 489 ... what year? [Re: 6bblgt] #1608887
04/18/14 08:52 PM
04/18/14 08:52 PM
SD
Z
Z
SD
Honestly, I'm probably not gonna take it apart for a while.
Re: 8.75 ... 489 ... what year? [Re: zrxkawboy] #1608888
04/18/14 10:36 PM
04/18/14 10:36 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Ok...then what's the casting date on the case?
Seeking:
Re: 8.75 ... 489 ... what year? [Re: John_Kunkel] #1608889
04/18/14 11:20 PM
04/18/14 11:20 PM
So then there must have been a significant overlap of the 742 and 489s. I say that because recently i acquired a 742 with a power lock date coded June 18 68. Which wouldn't be surprising I guess. Raises the question; when did the 742 cease?
Re: 8.75 ... 489 ... what year? [Re: 69CoronetRT] #1608890
04/18/14 11:26 PM
04/18/14 11:26 PM
SD
Z
Z
SD
Try as I might, I absolutely can't read it. I'm gonna pick up a grease crayon tomorrow at NAPA and see if that helps.
Re: 8.75 ... 489 ... what year? [Re: Pacnorthcuda] #1608891
04/19/14 02:28 PM
04/19/14 02:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As I stated in my first post, "some models" got the 489 in '68...not all.
Re: 8.75 ... 489 ... what year? [Re: John_Kunkel] #1608892
04/27/14 08:34 PM
04/27/14 08:34 PM
SD
Z
Z
SD
Just can't read the date code for anything. Oh well, doesn't really matter, I guess.
I did make another discovery today when I was out in the garage playing around. The diff has a 3.23 tag, but thought I'd make sure. Well, it is 3.23, but when I turned one side to count the turns, I found that the other axle was turning in the same direction! I was surprised, because I thought that if it was SG, the tag should say 3.23 S (it just says 3.23). Is that right? If so, hope I don't find a nasty surprise inside.
