School me on a 71 Hemi k member
#1608654
04/17/14 04:29 PM
04/17/14 04:29 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Hello, is there anything different from a 71 e body to a 71 b body? What about the mounts them self?
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
Re: School me on a 71 Hemi k member
[Re: 6bblgt]
#1608657
04/17/14 07:07 PM
04/17/14 07:07 PM
DaveDudek
N of Detroit
Mega parts is saying they are different.
[Re: DaveDudek]
#1608658
04/17/14 07:36 PM
04/17/14 07:36 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mounts are the same between the two K's, but the steering box angle is slightly different, but not really an issue, worse case is torsion bar interference with the pitman arm, but you could shim the steering box if need be...manual or power steering?
[Re: DaveDudek]
#1608661
04/17/14 10:40 PM
04/17/14 10:40 PM
Posts: 18,157 Mass
DAYCLONA
Mass
manual
Seems even with the correct K frame, manual steering boxes seem to suffer interference issues with the torsion bar and pitman arm...even the factory knew this, so shimming is par for the course
Mike
[Re: DaveDudek]
#1608664
04/18/14 09:51 PM
04/18/14 09:51 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
According to the Chrysler parts book they are the same for '71 E and B bodies. The book also shows 2 part numbers for '70 E bodies as already shown above by 6bblgt.
[Re: DaveDudek]
#1608665
04/18/14 10:16 PM
04/18/14 10:16 PM
Posts: 467 Coon Valley, WI
megaparts
Coon Valley, WI
Dave They are the same Did you call me the other day? I recall talking about how B-Body motor mounts are different then an E-Body to someone, but I was refering to the 1970 older B-Body. Maybe we just mis communicated. The E-Body and 1971 B-Body K-Frames are the exact same and use the same brackets and mounts. The 1970 Olde B-Body are different everything to the E-Body.
