School me on a 71 Hemi k member #1608654
04/17/14 04:29 PM
04/17/14 04:29 PM
N of Detroit
DaveDudek Offline OP
N of Detroit
Hello, is there anything different from a 71 e body to a 71 b body? What about the mounts them self?
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: School me on a 71 Hemi k member [Re: DaveDudek] #1608655
04/17/14 04:51 PM
04/17/14 04:51 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Same same GI. 71 B body is also the same as 70 E body.
Re: School me on a 71 Hemi k member [Re: 71birdJ68] #1608656
04/17/14 05:51 PM
04/17/14 05:51 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: School me on a 71 Hemi k member [Re: 6bblgt] #1608657
04/17/14 07:07 PM
04/17/14 07:07 PM
N of Detroit
N of Detroit
Mega parts is saying they are different.
Dave Dudek
Re: School me on a 71 Hemi k member [Re: DaveDudek] #1608658
04/17/14 07:36 PM
04/17/14 07:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mounts are the same between the two K's, but the steering box angle is slightly different, but not really an issue, worse case is torsion bar interference with the pitman arm, but you could shim the steering box if need be...manual or power steering?
Re: School me on a 71 Hemi k member [Re: DAYCLONA] #1608659
04/17/14 10:02 PM
04/17/14 10:02 PM
N of Detroit
N of Detroit
manual
Dave Dudek
Re: School me on a 71 Hemi k member [Re: DaveDudek] #1608660
04/17/14 10:39 PM
04/17/14 10:39 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
The steering box angle is the same between E body and 71-2 B body. 1970 and below B body is different.
You can use a E body K frame or a 71 B Body K frame Dave. Same for the mounts and engine brackets.
Re: School me on a 71 Hemi k member [Re: DaveDudek] #1608661
04/17/14 10:40 PM
04/17/14 10:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
manual
Seems even with the correct K frame, manual steering boxes seem to suffer interference issues with the torsion bar and pitman arm...even the factory knew this, so shimming is par for the course
Mike
Re: School me on a 71 Hemi k member [Re: DaveDudek] #1608662
04/18/14 02:56 PM
04/18/14 02:56 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Dave if Mega parts says there is a difference, then what are the saying the differences are?
1971 HEMI E BODY REGISTRY
Re: School me on a 71 Hemi k member [Re: hemicar1971] #1608663
04/18/14 04:59 PM
04/18/14 04:59 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Late-'70 E-body & all '71 HEMI "K"-frames are the same.
Re: School me on a 71 Hemi k member [Re: DaveDudek] #1608664
04/18/14 09:51 PM
04/18/14 09:51 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
According to the Chrysler parts book they are the same for '71 E and B bodies. The book also shows 2 part numbers for '70 E bodies as already shown above by 6bblgt.
Re: School me on a 71 Hemi k member [Re: DaveDudek] #1608665
04/18/14 10:16 PM
04/18/14 10:16 PM
Coon Valley, WI
megaparts Offline
megaparts  Offline
Coon Valley, WI
Dave They are the same Did you call me the other day? I recall talking about how B-Body motor mounts are different then an E-Body to someone, but I was refering to the 1970 older B-Body. Maybe we just mis communicated. The E-Body and 1971 B-Body K-Frames are the exact same and use the same brackets and mounts. The 1970 Olde B-Body are different everything to the E-Body.
