what can I expect #1608428
04/17/14 10:28 AM
04/17/14 10:28 AM
louisiana,usa
O
olemopar Offline OP
olemopar  Offline OP
O
louisiana,usa
changing from a 998 trans 456 gears 48to 5300 converter 2850 lb car 408ci changing to a pg 5000 to 5500 converter 513 gears car had 134 136 60ft 632 to6.36 depending on weather any thoughts
Re: what can I expect [Re: olemopar] #1608429
04/17/14 12:55 PM
04/17/14 12:55 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Thoughts? I think I had a hard time understanding what you were trying to say. More clarity needed.
Re: what can I expect [Re: Airwoofer] #1608430
04/17/14 02:37 PM
04/17/14 02:37 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
904/998 456 gear 4800/5600 stall size vert? 2 speed glide, 5200/5500 stall 513 gear. ist gear in 998 vs glide is differnt of course and the glide is all about the way you match the converter to your combo
Re: what can I expect [Re: olemopar] #1608431
04/17/14 02:45 PM
04/17/14 02:45 PM
The car will be easier to drive, one gear change instead of two, and it should be easier to hook on the bad tracks, if the new converter is good, no cheap converters
