Dave yeah Fatman is the one that makes the crossmember for your car
I would not go with that frontend if you want the GASSER look.
personally I would use the fatman unit on your car and look for something else to make into a GASSER.
Check on Ebay for mustang II stuff and you will find all kinds of frontend parts. I like the bigger brake kits(11") but they will run you about $100.00 more than the 9 1/2" stuff.
and I like the TUBE "A" armes top and bottom as it eliminates the factory mustang strut rod setup
I use the 70's mopar tilt columns but the Ididit stuff is real nice but costs more than a junkyard column.
I am glad you kept the car
Ron....
