Suspension overhaul?? #1607891
04/15/14 04:57 PM
04/15/14 04:57 PM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
I'm getting ready to gather parts to do the entire supsension on my Bee. It has stock rear springs and front hardware. Aftermarket disk brakes. I will be doing a lot of street driving and probably a bit of racing, as well.
What did you all do for a master kit for your car? Where did you order from? Did you go rubber or poly? Or rubber on the LCA and poly on the uppers? Torsion bars? Did you find a place to buy it all at once?
Thanks!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Suspension overhaul?? [Re: OhioMopar] #1607892
04/15/14 05:05 PM
04/15/14 05:05 PM
AndyF Offline
AndyF  Offline
The guys at Firm Feel can take care of what you need. The only thing I'll run on a street car is HD replacement bushings. I've tried most everything over the years and have found that the factory stuff works the best for street driving. Get a good brand like Moog and you should be good to go for a long time.
www.firmfeel.com is the place
Re: Suspension overhaul?? [Re: AndyF] #1607893
04/15/14 05:41 PM
04/15/14 05:41 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Thank you.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Suspension overhaul?? [Re: OhioMopar] #1607894
04/15/14 05:53 PM
04/15/14 05:53 PM
Definitely stay with quality OE type rubber (no poly) on the LCA's
Re: Suspension overhaul?? [Re: RapidRobert] #1607895
04/15/14 07:26 PM
04/15/14 07:26 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
That's the most common sentiment when it comes to LCA bushings.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Suspension overhaul?? [Re: OhioMopar] #1607896
04/15/14 10:08 PM
04/15/14 10:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Get the Moog problem solver upper bushings.Install opposite of instructions and get more caster.Thats if you run radial front tires.Rocky
Chrysler Firepower
Re: Suspension overhaul?? [Re: therocks] #1607897
04/15/14 11:38 PM
04/15/14 11:38 PM
tucson az
frank Offline
frank  Offline
tucson az
What do you mean opposite of instructions? Left side on right side; turn around--front on back? I thought the problem solver bushings were designed to give more caster--why swap them??
Re: Suspension overhaul?? [Re: frank] #1607898
04/16/14 12:18 AM
04/16/14 12:18 AM
IN
ahy Offline
ahy  Offline
IN
I run the Firm Feel "kit" and like it. Mine is all poly but agree the rubber LCA bushings are a benefit as they help position the LCA correctly. I had to add adjustable strut rods with my poly LCA bushings to get everything tight and in position for a correct and steady alignment.
Re: Suspension overhaul?? [Re: frank] #1607899
04/16/14 08:43 AM
04/16/14 08:43 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Curious on this as well.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Suspension overhaul?? [Re: OhioMopar] #1607900
04/16/14 09:31 AM
04/16/14 09:31 AM
BDW Offline
BDW  Offline
Like this
Re: Suspension overhaul?? [Re: BDW] #1607901
04/16/14 09:34 AM
04/16/14 09:34 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Okay, but why reverse the instructions?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Suspension overhaul?? [Re: OhioMopar] #1607902
04/16/14 11:00 AM
04/16/14 11:00 AM
Cuz the Moog intent of those is to move the UCA out laterally for more positive camber to compensate for a sagging or damaged subframe. We put the front one in as designed and put the arrow to the inside on the rearward one on each dr/pass side so that the front is moved outward as originally designed but we move the rear leg in which in effect moves the UBJ rearward (in a slight arc) for more positive caster.
Re: Suspension overhaul?? [Re: RapidRobert] #1607903
04/16/14 11:08 AM
04/16/14 11:08 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Aha. That makes sense.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Suspension overhaul?? [Re: OhioMopar] #1607904
04/16/14 11:45 AM
04/16/14 11:45 AM
WI. U.S.A.
DusTed74 Offline
DusTed74  Offline
WI. U.S.A.
I used all Moog parts. All rubber no poly. I bought all of it from Summit. They had the best prices.
Ted
Re: Suspension overhaul?? [Re: DusTed74] #1607905
04/16/14 11:49 AM
04/16/14 11:49 AM
Moog used to be a standby for quality but I hear they too are now being outsourced overseas & the quality is way less. Please tell me it ain't so
Re: Suspension overhaul?? [Re: RapidRobert] #1607906
04/16/14 01:56 PM
04/16/14 01:56 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
That's what I always understood, as well.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Suspension overhaul?? [Re: OhioMopar] #1607907
04/16/14 03:35 PM
04/16/14 03:35 PM
WI. U.S.A.
DusTed74 Offline
DusTed74  Offline
WI. U.S.A.
Time will tell. If it ever stops snowing here I'll be able to drive it again.
Ted
Re: Suspension overhaul?? [Re: OhioMopar] #1607908
04/16/14 05:17 PM
04/16/14 05:17 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Dodge Boy...
Used(PST)urethane in a PLYMOUTH..
Been in there for 20+ years...
I like it...
Re: Suspension overhaul?? [Re: RSNOMO] #1607909
04/16/14 07:12 PM
04/16/14 07:12 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Dodge Boy...
I like it...
But I want to drive mine. How do they do when it is in motion? Bazinga...
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Suspension overhaul?? [Re: OhioMopar] #1607910
04/16/14 07:27 PM
04/16/14 07:27 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
After 20,000 miles...
Just fine...
T'ain't no 'poodle'...
