Suspension overhaul??
#1607891
04/15/14 04:57 PM
04/15/14 04:57 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I'm getting ready to gather parts to do the entire supsension on my Bee. It has stock rear springs and front hardware. Aftermarket disk brakes. I will be doing a lot of street driving and probably a bit of racing, as well. What did you all do for a master kit for your car? Where did you order from? Did you go rubber or poly? Or rubber on the LCA and poly on the uppers? Torsion bars? Did you find a place to buy it all at once? Thanks!
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: Suspension overhaul??
[Re: OhioMopar]
#1607892
04/15/14 05:05 PM
04/15/14 05:05 PM
Posts: 31,023 Oregon
AndyF
The guys at Firm Feel can take care of what you need. The only thing I'll run on a street car is HD replacement bushings. I've tried most everything over the years and have found that the factory stuff works the best for street driving. Get a good brand like Moog and you should be good to go for a long time. www.firmfeel.com is the place
[Re: OhioMopar]
#1607894
04/15/14 05:53 PM
04/15/14 05:53 PM
RapidRobert
Definitely stay with quality OE type rubber (no poly) on the LCA's
[Re: RapidRobert]
#1607895
04/15/14 07:26 PM
04/15/14 07:26 PM
OhioMopar
Mt.Gilead, Ohio
That's the most common sentiment when it comes to LCA bushings.
[Re: OhioMopar]
#1607896
04/15/14 10:08 PM
04/15/14 10:08 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Get the Moog problem solver upper bushings.Install opposite of instructions and get more caster.Thats if you run radial front tires.Rocky
Chrysler Firepower
[Re: therocks]
#1607897
04/15/14 11:38 PM
04/15/14 11:38 PM
Posts: 2,138 tucson az
frank
tucson az
What do you mean opposite of instructions? Left side on right side; turn around--front on back? I thought the problem solver bushings were designed to give more caster--why swap them??
[Re: BDW]
#1607901
04/16/14 09:34 AM
04/16/14 09:34 AM
OhioMopar
Mt.Gilead, Ohio
Okay, but why reverse the instructions?
[Re: OhioMopar]
#1607902
04/16/14 11:00 AM
04/16/14 11:00 AM
RapidRobert
Cuz the Moog intent of those is to move the UCA out laterally for more positive camber to compensate for a sagging or damaged subframe. We put the front one in as designed and put the arrow to the inside on the rearward one on each dr/pass side so that the front is moved outward as originally designed but we move the rear leg in which in effect moves the UBJ rearward (in a slight arc) for more positive caster.
[Re: DusTed74]
#1607905
04/16/14 11:49 AM
04/16/14 11:49 AM
RapidRobert
Moog used to be a standby for quality but I hear they too are now being outsourced overseas & the quality is way less. Please tell me it ain't so
[Re: OhioMopar]
#1607910
04/16/14 07:27 PM
04/16/14 07:27 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
How do they do when it is in motion
After 20,000 miles...
Just fine...
T'ain't no 'poodle'...
[Re: RSNOMO]
#1607911
04/17/14 01:21 AM
04/17/14 01:21 AM
Posts: 15,855 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I did all Poly on my '89 Diplomat police car. It is definetly firm but not harsh and it's driven almost daily. Most came from firmfeel, but I got energy suspension for the sway bar end link bushings.
As far as Moog; I had heard they may have gone to some over seas sources so I emailed them. They responded they do have some countries of origin other than the US, and if I emailed the part number/numbers they would advise. I emailed my part numbers (upper/lower ball joints and tie rods and ends), and they responded they were US made. That was for my Diplomat. Who knows on other stuff, but if you go to the "Contact Us" on their website and email them the part number/numbers you will actually get an answer!
Facts are stubborn things.
[Re: larrymopar360]
#1607912
04/17/14 09:53 AM
04/17/14 09:53 AM
OhioMopar
Mt.Gilead, Ohio
Very good to know. Thanks.
