Convertors what stall
#1607765
04/15/14 11:01 AM
04/15/14 11:01 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
If you have a motor that makes peak torque at 5600 and peak hp at 7400 where would you want the stall spend of the convertor?
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Convertors what stall
[Re: 408strokerdart]
#1607770
04/15/14 02:05 PM
04/15/14 02:05 PM
1967dartgt
Hilltown Pa
This is for a 904 trans and 95% race car. I think you would shift it at 7800-8000 so you think it would want a 6800 convertor. Lenny will be getting the call just want some opinions and see what every one else is doing. Its for a friends car and we were talking about it yesterday. Brian what is your stall in your glide?
[Re: 1967dartgt]
#1607771
04/15/14 02:53 PM
04/15/14 02:53 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Lenny got my business and is in the process of building me another one right now. In the past with this motor, I had runabout 5600 stall against a torque peak of 5300, and 7,000 hp peak. I then tried it looser and wound up way loose, at about 6500. The car actually picked up, but so did the rpm at the stripe. Loose on the bottom means slip increase up top too. With the extra gear ratio of a Torqueflite a loose converter really helps consistency if you are on the edge to start with. It lowers the initial hit, and spreads the torque multiplication a bit more than a tighter converter. Plus if you spin a touch, a loose converter starts to lock up and actually pulls a touch harder rather than one close to the torque peak, which is already pulling as hard as it can. I was told the new converter ought to have 5 to 6 percent slip, which is based on my gear ratios, car weight. I asked for the new one to be set up for best performance, which I think allows it to be as tight as it can be for my application.
[Re: 1967dartgt]
#1607772
04/15/14 05:47 PM
04/15/14 05:47 PM
Posts: 3,456 Out West
408strokerdart
Out West
Mine stalls right at 6100.....wish I could try it just a tick higher.
[Re: MR_P_BODY]
#1607773
04/16/14 10:32 AM
04/16/14 10:32 AM
Posts: 176 NC USA
ultimatelenny
NC USA
On yours I would say 5800 but call the conv companies.. also makes a difference on what trans
X2
[Re: justinp61]
#1607775
04/17/14 10:17 AM
04/17/14 10:17 AM
Posts: 176 NC USA
ultimatelenny
NC USA
Lenny, get off the computer and to work on my converter.
Hey Justin, boy sneak on the board for a minute and get nabbed!!! LOL Starting on your piece this morning, should be ready to ship Monday.
[Re: ultimatelenny]
#1607776
04/17/14 10:24 AM
04/17/14 10:24 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
It's all good, looking forward to running it.
[Re: justinp61]
#1607777
04/17/14 01:05 PM
04/17/14 01:05 PM
Posts: 176 NC USA
ultimatelenny
NC USA
Sorry Justin, here I am thinking it is Friday, if all goes well you should leave tomorrow.
[Re: ultimatelenny]
#1607778
04/17/14 01:27 PM
04/17/14 01:27 PM
justinp61
W. Kentucky
