440 cam ? #1607492
04/14/14 04:59 PM
04/14/14 04:59 PM
NY
70440+6bbl Offline OP
NY
Putting together a 440 for a friends '70 Challenger. The shortblock was built sveral years ago and consists of the following parts:
'70 440 block .030
TRW L2295 pistons (yes, boat anchors, but what we have)
Eagle H-beams
Mellings std volume pump
.010/.010 forged crank
ARP main studs
balanced rotating assembly
Heads are Edelbrock 84cc
Comp Cams 1.5 roller rockers
Will this following cam be a good choice for a fair weather cruiser? Car is a 4-spd with 3.55 suregrip.
It's an old stock Engle HL26 solid lifter grind. Found these specs on the web: 254* Dur. @ .050" and .513" lift with 1.5 rockers
Re: 440 cam ? [Re: 70440+6bbl] #1607493
04/14/14 05:25 PM
04/14/14 05:25 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
4.10s would be better, as long as he has headers and a good intake and carb yes. It will have a pretty lopey idle and it will be a screamer.
It should be good cam for a mid to high 11 second time slip, if he's not fussy and doesn't want a stock idle it'll work. If he really just wants a crusier I'd go smaller. Any idea on the LSA? I'm assuming 108.
Re: 440 cam ? [Re: GTX MATT] #1607494
04/14/14 05:35 PM
04/14/14 05:35 PM
NY
NY
Thanks for the reply Matt. The intake is an Eddy Perf RPM and the carb is an 850 Holley DP. TTI 1 7/8" headers and 2.5" exhaust. The gears are the one thing he won't change out. He likes to be a freeway flyer
According to the second response from Chris at Engle, the LSA is 108 or 110.
This is the first response from Engle tech:
Hi,
that is a big block chevy grind . It is .252’ duration at .050”.342” cam lift .292’ running duration .513”lift
The lash is .018”int .020”ex cold for Iron heads Chris
Re: 440 cam ? [Re: 70440+6bbl] #1607495
04/14/14 05:44 PM
04/14/14 05:44 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
I'm no guru when it comes to cams and specs, but a friend of mine has a similar setup on his car, and he went with a Lunati vodoo 60303. It has a nice little lope to it, but drives great. Get a little heavy footed and it wakes up real nice.
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: 440 cam ? [Re: 70440+6bbl] #1607496
04/14/14 06:47 PM
04/14/14 06:47 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Is the 2295 the DOMED piston ??? If it is his compression ratio is going to require him to mix in race gas .
Re: 440 cam ? [Re: JohnRR] #1607497
04/14/14 06:56 PM
04/14/14 06:56 PM
NY
NY
Yes it is John. From what I have read here, seems they don't make nearly the advertised cr.
My '71 GTXs 440 has the same pistons and with the original 346 heads (done by Valley Head Service in CA, years ago) and stamped 87cc, along with a Racer Brown ssh-25 cam, I didn't really have any detonation issues running 93 octane, unless I lugged it up a hill in fourth.
Re: 440 cam ? [Re: 70440+6bbl] #1607498
04/14/14 10:09 PM
04/14/14 10:09 PM
The shortblock was built sveral years ago.
I'd plug all the specs into Kieth Blacks calculator & see what SCR you have & post the number here. You said you wanted a mild cruiser so I'd listen to what the cam guys who have already posted here have said & go with something mild(er)
Re: 440 cam ? [Re: 70440+6bbl] #1607499
04/15/14 11:26 AM
04/15/14 11:26 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run Ross 12.5 domes in my 440.Stealth heads and Comp .588 cam.I only need to mix race gas if Im going to run it hard or at the track.It runs 93 pump gas almost all the time.Just cant get into it hard or the valves will clatter.Rocky
Chrysler Firepower
Re: 440 cam ? [Re: therocks] #1607500
04/15/14 11:43 AM
04/15/14 11:43 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Call Scott at straightline. I ran his 540ish grind and it ran real good. As for compression You could always go w/ a cometic gasket. This motor has .057 gaskets. I'm also running a comp cams 588 solid roller.
Coming soon!!!!
Re: 440 cam ? [Re: Mr.Yuck] #1607501
04/15/14 02:07 PM
04/15/14 02:07 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Regardless of the cam I hope the stock valve notches have been recut.As built they are way small and you will have issues in the outside corners of the cuts.That will limit cam choice.I have used them many times,with 86 cc heads and no milling of the block could be as low as 10.3. With 79cc heads and .000 deck they are easily can be 13-1.
Cam wise,I have had great success with the Voodoo line.60304 would be a very good choice.
Leave the gun.......take the Cannoli's....Mike
Re: 440 cam ? [Re: mike s] #1607502
04/15/14 10:23 PM
04/15/14 10:23 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
How far in the hole are those 2295's? I have run 268 at 050 with the 2295's. Mine where around 030 down. The heads where 906s, milled about 020 with Manley 214 pro flows. That motor was built 30 years ago so I'm a little fuzy the the exact specs. Oh and with that 4spd, if you put tires that will allow you to hook 'n book, you'll bust that 8.75
Re: 440 cam ? [Re: mike s] #1607503
04/15/14 11:31 PM
04/15/14 11:31 PM
NY
NY
No, they are box stock and the heads are 84cc. The block only had a clean-up cut.
Re: 440 cam ? [Re: 6PACMAC] #1607504
04/15/14 11:35 PM
04/15/14 11:35 PM
NY
NY
I'm going to check the deck height this weekend. I'm betting the flat part is way lower than .030. And, he plans on a Dana soon
Re: 440 cam ? [Re: 70440+6bbl] #1607505
04/16/14 12:27 AM
04/16/14 12:27 AM
IN
ahy Offline
ahy  Offline
IN
With a MT, 3.55's and mostly street driving, I'd suggest a smaller cam - 235ish @.050 intake duration - may make the car more fun with mid range torque and "reasonable" manners.
Except the big cam may help in dealing with high CR and avoiding detonation. Agree as others have posted, figuring the "real" CR and PV clearances matters a lot.
