Page 1 of 3 1 2 3
NOT GOING TO MAKE IRWINDALE THURSDAY............. #1607306
04/14/14 02:34 PM
04/14/14 02:34 PM
State of confusion
Thumperdart Offline OP
State of confusion
Thinking about taking my junk out one more time before it gets too hot so is anyone else interested in an 1/8th mile boogie?
Re: IRWINDALE THIS THURSDAY.......................... [Re: Thumperdart] #1607307
04/14/14 06:59 PM
04/14/14 06:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
While I cant join the 1/8 mile boogie, I will be interested in your results. Right now I only have to beat a what 9.79 or so? I want to see if that changes.
Re: IRWINDALE THIS THURSDAY.......................... [Re: Sport440] #1607308
04/14/14 07:14 PM
04/14/14 07:14 PM
State of confusion
State of confusion
Almost sure we`re goin and my goal is a 6.10 which may or may not be doable so I`m going to make some small hits and hopefully get my 60`s back in the 1.36 range then let er rip............. Still on my old tires though...........
Re: IRWINDALE THIS THURSDAY.......................... [Re: Thumperdart] #1607309
04/14/14 08:32 PM
04/14/14 08:32 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Track should still be good since they just had a summit race yesterday. see ya there if you go.
Re: IRWINDALE THIS THURSDAY.......................... [Re: Thumperdart] #1607310
04/14/14 08:42 PM
04/14/14 08:42 PM
gregsdart Offline
gregsdart  Offline
Good luck! Now if you were up here, the temp is 36 degrees, and the barometer is pegged!
Re: IRWINDALE THIS THURSDAY.......................... [Re: gregsdart] #1607311
04/14/14 10:27 PM
04/14/14 10:27 PM
State of confusion
State of confusion
I`ll know for sure wed. and 36 and fat baro. sound awesome IF it hooked. This is my last effort for a while unless I can make Famoso soon..............
Re: IRWINDALE THIS THURSDAY.......................... [Re: Thumperdart] #1607312
04/15/14 06:22 PM
04/15/14 06:22 PM
California
GTXMEX Offline
GTXMEX  Offline
California
Maybe Ill head over and you can fix thr timing on my car...
Re: IRWINDALE THIS THURSDAY.......................... [Re: GTXMEX] #1607313
04/15/14 09:41 PM
04/15/14 09:41 PM
State of confusion
State of confusion
If we can help you by all means look for my junk............my lic. plate says; BNTHMPD............
Re: IRWINDALE THIS THURSDAY.......................... [Re: Thumperdart] #1607314
04/15/14 09:53 PM
04/15/14 09:53 PM
California
GTXMEX Offline
GTXMEX  Offline
California
Cool! You good with timing and got a light?
Re: IRWINDALE THIS THURSDAY.......................... [Re: GTXMEX] #1607315
04/15/14 10:47 PM
04/15/14 10:47 PM
State of confusion
State of confusion
Yes and Yes...............
Re: IRWINDALE THIS THURSDAY.......................... [Re: GTXMEX] #1607316
04/15/14 10:48 PM
04/15/14 10:48 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Have fun Thumper
Re: IRWINDALE THIS THURSDAY.......................... [Re: roadhazard] #1607317
04/15/14 10:50 PM
04/15/14 10:50 PM
State of confusion
State of confusion
Yes sir and Pettis will be gettin in touch w/ya soon..........
Any gusses on et`s and mph from anyone?
Re: IRWINDALE THIS THURSDAY.......................... [Re: Thumperdart] #1607318
04/15/14 11:55 PM
04/15/14 11:55 PM
California
GTXMEX Offline
GTXMEX  Offline
California
Cool, im gonna try and make it there for a bit.
Re: IRWINDALE THIS THURSDAY.......................... [Re: GTXMEX] #1607319
04/16/14 12:31 AM
04/16/14 12:31 AM
State of confusion
State of confusion
Re: IRWINDALE THIS THURSDAY.......................... [Re: Thumperdart] #1607320
04/16/14 12:34 AM
04/16/14 12:34 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
You have that car dialed in pretty well, so increases will be minor and effected by the current temp, humidity and barometric pressure or what other racers refer to as DA.
As I recall the last time out, the weight loss thing didnt go as projected, because of a bad hook.
The new change is the carb fix. So combined with the weight loss and the carb fix, if you have a great DA, and a Hook with your old tires, you might get your 6.10 I know you have the skills.
Correct me if Im wrong on any of the above, just going by memory, thats getting shorter and shorter.
Re: IRWINDALE THIS THURSDAY.......................... [Re: GTXMEX] #1607321
04/16/14 12:40 AM
04/16/14 12:40 AM
California
GTXMEX Offline
GTXMEX  Offline
California
What time will you get there?
Re: IRWINDALE THIS THURSDAY.......................... [Re: Sport440] #1607322
04/16/14 01:21 AM
04/16/14 01:21 AM
State of confusion
State of confusion
The new change is the carb fix. So combined with the weight loss and the carb fix, if you have a great DA, you might get your 6.10 I know you have the skills.
When I went 6.20 at 111.17 it was during the day at 85+ degrees and a 1.42 60 which is a bit off of my 1.36 60 ft. It should be cooler and I`ve changed shock angles, went to sliders, added 2nd batt. back and it`s tuned pretty good so we`ll soon see............
Re: IRWINDALE THIS THURSDAY.......................... [Re: Thumperdart] #1607323
04/16/14 02:00 AM
04/16/14 02:00 AM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
Good luck Dom!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: IRWINDALE THIS THURSDAY.......................... [Re: johnnycuda] #1607324
04/16/14 02:05 AM
04/16/14 02:05 AM
State of confusion
State of confusion
Thankxx...............
Re: IRWINDALE THIS THURSDAY.......................... [Re: Thumperdart] #1607325
04/16/14 07:54 AM
04/16/14 07:54 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Defiantly keep us updated as your car always amazes me with it's performance
Page 1 of 3 1 2 3
