NOT GOING TO MAKE IRWINDALE THURSDAY.............
#1607306
04/14/14 02:34 PM
04/14/14 02:34 PM
Thumperdart
State of confusion
Thinking about taking my junk out one more time before it gets too hot so is anyone else interested in an 1/8th mile boogie?
Re: IRWINDALE THIS THURSDAY..........................
[Re: roadhazard]
#1607317
04/15/14 10:50 PM
04/15/14 10:50 PM
Thumperdart
State of confusion
Yes sir and Pettis will be gettin in touch w/ya soon.......... Any gusses on et`s and mph from anyone?
[Re: Sport440]
#1607322
04/16/14 01:21 AM
04/16/14 01:21 AM
Thumperdart
State of confusion
You have that car dialed in pretty well, so increases will be minor and effected by the current temp, humidity and barometric pressure or what other racers refer to as DA.
As I recall the last time out, the weight loss thing didnt go as projected, because of a bad hook.
The new change is the carb fix. So combined with the weight loss and the carb fix, if you have a great DA, you might get your 6.10 I know you have the skills.
Correct me if Im wrong on any of the above, just going by memory, thats getting shorter and shorter.
When I went 6.20 at 111.17 it was during the day at 85+ degrees and a 1.42 60 which is a bit off of my 1.36 60 ft. It should be cooler and I`ve changed shock angles, went to sliders, added 2nd batt. back and it`s tuned pretty good so we`ll soon see............
[Re: Thumperdart]
#1607323
04/16/14 02:00 AM
04/16/14 02:00 AM
Posts: 860 lancaster,california
johnnycuda
Good luck Dom!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
