Re: 1970 Duster Repro Fuel Tank
[Re: FJR doc]
#1607296
04/15/14 09:15 AM
04/15/14 09:15 AM
Challenger 1
Cincinnati, Ohio
I'm at a point where I am trying to decide what to do about my fuel tank on my 340. The original tank has outer surface rust but looks to be very clean inside.....never leaked. A search on repro gas tanks on here indicates that they don't look exactly like the original as they also are stamped for longitudinal straps for 67. I was thinking about calling my local radiator shop to see if they can clean the original. Anybody have any ideas as to whether this is a good idea or a bad idea?
If it's clean inside, then no reason to get the radiator shop involved, IMO. Either way I would not use them even if it's nasty inside, then it's time for a repo.
I recently cleaned up a used one I had in storage for 30 years. The inside was spotless with fairly heavy rust on the outside. I sand blasted mine after pressure washing.
Then I use Eastwoods Tank Tone paint on it. The paint don't look like galvanizing, but I like the looks and does offer good protection as I have used it years ago also.
Rusty outside bottom. Freshly blasted before paint.
With 2 larger openings, it not not too hard to pressure wash out the inside. Then I use like a pint or 2 of methanol, swish it around inside and it instantly drys out the inside. Just a idea for you and I didn't give my local radiator man guy any money.
[Re: Challenger 1]
#1607297
04/15/14 09:42 PM
04/15/14 09:42 PM
Posts: 499 Brownstown, PA
FJR doc
Brownstown, PA
The radiator shop wanted $250 to do the tank.....forget that. I could get a repro tank but it bothers me that they don't have the correct external appearance. It would be easier to just get a Spectra tank but it's a Mopar restoration and nothing is simple. I could easily pressure wash the inside. Could light interior rust be removed with a fill of Evaporust or the lemon juice/salt mix? Should the interior be coated with a sealant afterwards? I suppose there is no way to replicate the external appearance once the outer surface has rusted through.
[Re: FJR doc]
#1607298
04/16/14 01:44 PM
04/16/14 01:44 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
If there is rust on the inside you are going to have pinholes thru the tank more than likely , for now just buy the repop tank and live with it till you can find a good tank that is in the budget. I have seen NOS tanks , but they were in the 'hood of 600 .. I hardly look under the car.
Maybe we should start and email campaign telling Spectre the way the tanks are is unacceptable to be incorrect for every year except 1 ?
