Re: Setting up a 440 with a H.S.D. intake and a thermoquad
[Re: JohnRR]
#1606898
04/14/14 02:10 AM
04/14/14 02:10 AM
Posts: 75,050 U.S.S.A.
JohnRR
U.S.S.A.
[Re: Rob C]
#1606901
04/17/14 09:06 AM
04/17/14 09:06 AM
Posts: 409 Lexington NC
twinscrew698
Lexington NC
If i remember the Holley is taller than a stock intake and you are going to find your cables too short and the throttle bracket does not fit correctly on the intake and might have to find a longer cable and maybe different throttle brackets! Maybe something along this might help and try a cable kickdown if yours does not work. http://arengineering.com/products/throttle-bracket-kit-440/
[Re: mopfried]
#1606903
04/17/14 02:26 PM
04/17/14 02:26 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I don't know if any of this might be of some help. The issue I ran into was that the different setup moved the linkage up, forward and out towards the drivers valve cover quite a bit. I modified the stock linkage and bracket to fit. It wasn't too difficult. Cable was too short so I made a simple extension. The bracket that bolts on the carb linkage is off the shelf (Mopar adapter from Edelbrock). The throttle cable and kick down bracket was flattened on the bench vise to make it reach higher and over. The kick down linkage was straightened a bit and is installed from the outside-in at the rear pivot point, effectively moving it out towards the left. It works perfectly and its easy to adjust, strong, simple and looks almost stock.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1606904
04/17/14 08:06 PM
04/17/14 08:06 PM
JohnRR
U.S.S.A.
Turn that rod end around 180 degrees in the bell crank , the spring should be straight and not crossing anything .
