old direct connection dual plug hemi valve cover parts! #1606712
04/13/14 09:11 AM
04/13/14 09:11 AM
MICHIGAN
BB65Barracuda Offline OP
MICHIGAN
I had to use the dual plug seals on my single plug headed 426 Hemi in the coronet. I used plugs to accommodate the fact that they are single plug heads.
Is anyone repoping these sealing plates for these old Dual plug valve covers? Or is there a source to buy them? I would really like to keep the valve covers on her, but I think the plugs I installed look a little hokey!
They don't leak even with the little bit of reshaping I had to do because of the spring height.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: old direct connection dual plug hemi valve cover parts! [Re: BB65Barracuda] #1606713
04/13/14 10:51 AM
04/13/14 10:51 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Yes I think I have see them on ebay new. I wanted to they those covers as a day 2 look.
Re: old direct connection dual plug hemi valve cover parts! [Re: 71birdJ68] #1606714
04/13/14 12:06 PM
04/13/14 12:06 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is what you're looking for. They're from an NOS set I sold years ago. IIRC, this stock setup doesn't really work well for the street as the blockoff plate is held to the valve cover by the active spark plug tube. With the plate being held on one end only, the seal over the inactive plug hole is not good and leaks. I'm thinking your plug approach is really a superior move.
Re: old direct connection dual plug hemi valve cover parts! [Re: BB65Barracuda] #1606715
04/14/14 01:06 AM
04/14/14 01:06 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi ,
just got a air of those covers also , what plugs did you use ?
originals i dont think sealed that well ?
thank you !
