87 Dakota 3.9 to 5.2 tc? #1606434
04/12/14 08:10 PM
04/12/14 08:10 PM
eastern long island,NY
JeepJimmy Offline OP
87 Dakota had a 3.9 carb, switching to a 96 5.2. (converting to carb) its a 904 Lockup transmission. can I reuse the torque converter? and which flexplate should I use? from everything I figure out. the 3.9 should be the same as a 5.2?? any ideas?
70 duster 360magnum, 1975 jeep j-10.
Re: 87 Dakota 3.9 to 5.2 tc? [Re: JeepJimmy] #1606435
04/14/14 03:57 AM
04/14/14 03:57 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Everything I've read tells me the 5.2 should bolt up to the 3.9 trans. Don't think the flex plate matters either. Not sure how the 3.9 trans will hold up to the 5.2 under hard thrashing, but would probably work under normal driving (whatever that means ) Gene
Re: 87 Dakota 3.9 to 5.2 tc? [Re: JeepJimmy] #1606436
04/14/14 10:54 AM
04/14/14 10:54 AM
scratchnfotraction Offline
you may need a 96 5.2 flex plate and 96 5.2 TC in the 89 trans
the 89 is pre-magnum and 96 is magnum both N balance but may have slight difference in balance between Pre-mag LA and magnum engines.
but the bellhousing bolts right up from V6 to small block LA/magnum v-8
I have a 88 v-6 flywheel on my 91 5.2 NV4500 both were pre-mag engines though.
you may need the 5.2 flexplate/TC if you need a crank sensor?
Re: 87 Dakota 3.9 to 5.2 tc? [Re: scratchnfotraction] #1606437
04/14/14 01:58 PM
04/14/14 01:58 PM
dogdays Offline
dogdays  Offline
Neutral balance is neutral balance, no difference between LA and 5.2Mag as far as that goes.
R.
