overheating hemi??? #1606389
04/12/14 06:35 PM
04/12/14 06:35 PM
maine
jonccjr Offline OP
jonccjr  Offline OP
maine
I have a 2005 dodge magnum r/t 5.7l hemi that is overheating. I verified today that my thermostat is good with the boiling water test, what should i test next and how?
Re: overheating hemi??? [Re: jonccjr] #1606390
04/12/14 06:37 PM
04/12/14 06:37 PM
johnmilner Offline
johnmilner  Offline
electric fans????????????
Re: overheating hemi??? [Re: jonccjr] #1606391
04/12/14 10:24 PM
04/12/14 10:24 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Welcome to Moparts.
(I think I know this guy).
Re: overheating hemi??? [Re: johnmilner] #1606392
04/12/14 10:31 PM
04/12/14 10:31 PM
maine
jonccjr Offline OP
jonccjr  Offline OP
maine
so let me tell more of the story. I had this problem last fall, I changed the thermostat problem solved? well till yesterday it was. I went and had the oil changed, they topped off the coolant and now i can't go five miles without it overheating. It has two electric fans on the radiator.
Re: overheating hemi??? [Re: JonC] #1606393
04/12/14 10:32 PM
04/12/14 10:32 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Overheating at traffic lights? johnmilner might be on to something.
Re: overheating hemi??? [Re: jonccjr] #1606394
04/12/14 11:58 PM
04/12/14 11:58 PM
with it overheating that fast k.i.s.s. confirm that the fans are operating. Pull the stat & check it (Murphys law/coincidences happen)
Re: overheating hemi??? [Re: jonccjr] #1606395
04/13/14 12:58 PM
04/13/14 12:58 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My guess would be a clogged radiator if you can hear the fans run. It happens a lot because the newer radiators have such small tubes in them now.
Any codes?
Re: overheating hemi??? [Re: Challenger 1] #1606396
04/13/14 02:59 PM
04/13/14 02:59 PM
maine
jonccjr Offline OP
jonccjr  Offline OP
maine
thanks for the idea. I got two codes 0158,2181
Re: overheating hemi??? [Re: RapidRobert] #1606397
04/13/14 03:24 PM
04/13/14 03:24 PM
maine
jonccjr Offline OP
jonccjr  Offline OP
maine
I actually ran it without a stat and it still overheated
Re: overheating hemi??? [Re: jonccjr] #1606398
04/13/14 05:21 PM
04/13/14 05:21 PM
johnmilner Offline
johnmilner  Offline
you didnt lose your belt did you?
Re: overheating hemi??? [Re: johnmilner] #1606399
04/13/14 05:29 PM
04/13/14 05:29 PM
maine
jonccjr Offline OP
jonccjr  Offline OP
maine
Belt is still present and seems to have enough tension.
Re: overheating hemi??? [Re: jonccjr] #1606400
04/13/14 05:32 PM
04/13/14 05:32 PM
johnmilner Offline
johnmilner  Offline
are the fans working with the ac off?
Re: overheating hemi??? [Re: johnmilner] #1606401
04/13/14 05:43 PM
04/13/14 05:43 PM
maine
jonccjr Offline OP
jonccjr  Offline OP
maine
I hate to ask but I have to. Do you mean the radiator fans?
Re: overheating hemi??? [Re: jonccjr] #1606402
04/13/14 08:50 PM
04/13/14 08:50 PM
johnmilner Offline
johnmilner  Offline
yes
Re: overheating hemi??? [Re: johnmilner] #1606403
04/13/14 10:40 PM
04/13/14 10:40 PM
maine
jonccjr Offline OP
jonccjr  Offline OP
maine
I never saw it running anytime I have been under the hood. Is there a way to check this?
Re: overheating hemi??? [Re: jonccjr] #1606404
04/14/14 12:56 PM
04/14/14 12:56 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
If your radiator is a 2 pass design the radiator can fail in a way as to bypass the tubes. Check to see if the radiator is hot everywhere.
Re: overheating hemi??? [Re: jonccjr] #1606405
04/14/14 05:15 PM
04/14/14 05:15 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I just changed the radiator in my 5.7 Magnum last month. Not expensive or terribly difficult. However, if you are overheating so quickly it does sound like the radiator fans not turning on.
Re: overheating hemi??? [Re: jonccjr] #1606406
04/14/14 05:17 PM
04/14/14 05:17 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Just look at the fans with the motor running. After the car is warm, the fans should kick on automatically to prevent overheating.
P2181-COOLING SYSTEM PERFORMANCE
P0158-o2 Sensor 2/2 Circuit High
Re: overheating hemi??? [Re: Tom_440] #1606407
04/14/14 08:36 PM
04/14/14 08:36 PM
maine
jonccjr Offline OP
jonccjr  Offline OP
maine
Turns out it was the fans. I have been so hung up on what seemed like a lack of fluid circulation. Cost me $200 for a new set and problem solved. The thing I don't understand is why this all occurred after I had the coolant topped off.
Re: overheating hemi??? [Re: jonccjr] #1606408
04/14/14 09:09 PM
04/14/14 09:09 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks for letting us know how it turned out.
Wonder if the coolant needing to be topped off was caused by the fans failure?
In other words the fans failed first?
