Broken oil pickup removal #1606283
04/12/14 01:48 PM
04/12/14 01:48 PM
California
mickm Offline OP
mickm  Offline OP
California
My pickup tube cracked right after the boss, and so now the threaded section is left up in the boss, the tube broke when it was taken out.
So how do I get in there and remove that?
Re: Broken oil pickup removal [Re: mickm] #1606284
04/12/14 01:53 PM
04/12/14 01:53 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Look for a left handed easy out or drill bit large enough to bite the internal diameter and turn it out.
Re: Broken oil pickup removal [Re: mickm] #1606285
04/12/14 02:06 PM
04/12/14 02:06 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
Was this in your Hemi? I had the same problem with the stock Mopar 6 qt. pan, 1/2" pu in my Hemi. Luckily I was just cruising in the neighborhood when I noticed erratic oil pressure. I got it home before it broke off completely. I used an easy-out with no problems and replaced the PU with another MP. unit. so far, so good.
Re: Broken oil pickup removal [Re: mickm] #1606286
04/12/14 02:07 PM
04/12/14 02:07 PM
You might see if you can jamb a cheap HF NPT tap up there & get it to bite CCW into the piece
Re: Broken oil pickup removal [Re: RapidRobert] #1606287
04/12/14 02:42 PM
04/12/14 02:42 PM
California
mickm Offline OP
mickm  Offline OP
California
Yes, it's the hemi. Had anothe post about the oil pressure loss, just found out this is the problem.
Re: Broken oil pickup removal [Re: mickm] #1606288
04/12/14 05:20 PM
04/12/14 05:20 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
In the other thread you wrote
Oil pickup tube cracked two threads below the boss! Woohoo! Not nearly as bad as it could have been!
It sounds like an EZ-Out type extractor is what you'll need to get it out.
Just find one that the correct size to get it to bite and back out the broken piece.
Re: Broken oil pickup removal [Re: mickm] #1606289
04/12/14 06:15 PM
04/12/14 06:15 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Nuway tools in Santa Clara, or a plumbing supply store with have the extractors. You tap them in and turn them out.
Are you going to inspect a rod bearing or two?
Re: Broken oil pickup removal [Re: jbc426] #1606290
04/12/14 07:24 PM
04/12/14 07:24 PM
California
mickm Offline OP
mickm  Offline OP
California
Yes, definitely going to look at some bearings.
Re: Broken oil pickup removal [Re: mickm] #1606291
04/12/14 10:29 PM
04/12/14 10:29 PM
northern illinois
jburt Offline
jburt  Offline
northern illinois
menards, for removing lawn sprinkler stand pipes. tapped it just a bit and it came out for me. primitive but effective
Re: Broken oil pickup removal [Re: jburt] #1606292
04/12/14 10:57 PM
04/12/14 10:57 PM
California
mickm Offline OP
mickm  Offline OP
California
Where do you get such a thing? I can practice on the pickup tube a And see how well it works and go from there.
Re: Broken oil pickup removal [Re: mickm] #1606293
04/12/14 11:03 PM
04/12/14 11:03 PM
northern illinois
jburt Offline
jburt  Offline
northern illinois
i got it at menards. if you dont have menards out there they are like a home depot. ace hardware may even have it. any place that sells parts for lawn sprinklers will have it.
Re: Broken oil pickup removal [Re: jburt] #1606294
04/14/14 01:41 PM
04/14/14 01:41 PM
dogdays Offline
dogdays  Offline
Sears or Ace Hardware or online, there are some really nice screw extractors out there, just look.
R.
Re: Broken oil pickup removal [Re: mickm] #1606295
04/14/14 02:44 PM
04/14/14 02:44 PM
California
mickm Offline OP
mickm  Offline OP
California
great, thanks everyone. will post the results.
Re: Broken oil pickup removal [Re: mickm] #1606296
04/14/14 04:39 PM
04/14/14 04:39 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Wow, dodged a big bullit. never thought that would be a problem. Hopefully the bearings are ok. Things have a way of working out.
Re: Broken oil pickup removal [Re: mickm] #1606297
04/14/14 04:46 PM
04/14/14 04:46 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Broken oil pickup removal [Re: Challenger 1] #1606298
04/14/14 04:49 PM
04/14/14 04:49 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
You'll never get it out, the block is junk, just give it to me
Re: Broken oil pickup removal [Re: GTX MATT] #1606299
04/14/14 05:18 PM
04/14/14 05:18 PM
California
mickm Offline OP
mickm  Offline OP
California
dude, i think you're right. i'm done with this! just going to stick a small block in and be done with it.
what's your address? i'll pull that thing out, throw it in a cardboard box, and you can deal with that piece of junk!!
Re: Broken oil pickup removal [Re: Lee446] #1606300
04/14/14 09:53 PM
04/14/14 09:53 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
......I had the same problem with the stock Mopar 6 qt. pan, 1/2" pu in my Hemi......
That's interesting. I've seen two Hemi pickups fail in my short and uneventful life and in both cases the owners told me they didn't check to make sure the pickup contacted the pan. The other item I've noticed is that the stock pickups have rolled threads and the aftermarket ones I've seen have cut threads. IMHO the stress riser at the end of the cut thread is a problem just waiting to happen although I'll admit I haven't seen it cause a problem in practice.
Re: Broken oil pickup removal [Re: 6PakBee] #1606301
04/14/14 10:14 PM
04/14/14 10:14 PM
6pakbee, interesting you mentioned the different (cut/rolled) threads as I tried to thread a 1/2 pickup (MP iirc) with a 1/2 NPT die & it would not work & I had no clue what the problem was.
Re: Broken oil pickup removal [Re: 6PakBee] #1606302
04/14/14 10:49 PM
04/14/14 10:49 PM
California
mickm Offline OP
mickm  Offline OP
California
i did check that there was clearance to the bottom of the pan. however, the engine was on a cherry picker with a tire underneath it, and i came out the next morning, and the engine was on the tire. there was still plenty of tension on the chain, so the entire weight of the engine was not resting on the pan.
i didn't think much of it, (because the entire weight of the engine wasn't on the pan), and put the engine in. it was only after it was installed that i noticed the pan was slightly dented in. it didn't seem that bad at all, so i decided i would leave it and deal with it later. never occurred to me that it might have pushed the pan into the pickup and stressed it.
i haven't cleaned out the pan to investigate the bottom of it yet. i assume that if it did contact the bottom of the pan enough to stress it, there will be marks on the inside of the pan, so hopefully that will show me something.
