Re: Broken oil pickup removal
[Re: mickm]
#1606286
04/12/14 02:07 PM
04/12/14 02:07 PM
RapidRobert
You might see if you can jamb a cheap HF NPT tap up there & get it to bite CCW into the piece
[Re: mickm]
#1606288
04/12/14 05:20 PM
04/12/14 05:20 PM
Posts: 10,133 A Red State
SNK-EYZ
A Red State
In the other thread you wrote Quote:
Oil pickup tube cracked two threads below the boss! Woohoo! Not nearly as bad as it could have been!
It sounds like an EZ-Out type extractor is what you'll need to get it out.
Just find one that the correct size to get it to bite and back out the broken piece.
[Re: mickm]
#1606289
04/12/14 06:15 PM
04/12/14 06:15 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Nuway tools in Santa Clara, or a plumbing supply store with have the extractors. You tap them in and turn them out.
Are you going to inspect a rod bearing or two?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: GTX MATT]
#1606299
04/14/14 05:18 PM
04/14/14 05:18 PM
Posts: 4,179 California
mickm
California
You'll never get it out, the block is junk, just give it to me
dude, i think you're right. i'm done with this! just going to stick a small block in and be done with it.
what's your address? i'll pull that thing out, throw it in a cardboard box, and you can deal with that piece of junk!!
[Re: 6PakBee]
#1606301
04/14/14 10:14 PM
04/14/14 10:14 PM
RapidRobert
6pakbee, interesting you mentioned the different (cut/rolled) threads as I tried to thread a 1/2 pickup (MP iirc) with a 1/2 NPT die & it would not work & I had no clue what the problem was.
[Re: 6PakBee]
#1606302
04/14/14 10:49 PM
04/14/14 10:49 PM
mickm
California
i did check that there was clearance to the bottom of the pan. however, the engine was on a cherry picker with a tire underneath it, and i came out the next morning, and the engine was on the tire. there was still plenty of tension on the chain, so the entire weight of the engine was not resting on the pan.
i didn't think much of it, (because the entire weight of the engine wasn't on the pan), and put the engine in. it was only after it was installed that i noticed the pan was slightly dented in. it didn't seem that bad at all, so i decided i would leave it and deal with it later. never occurred to me that it might have pushed the pan into the pickup and stressed it.
i haven't cleaned out the pan to investigate the bottom of it yet. i assume that if it did contact the bottom of the pan enough to stress it, there will be marks on the inside of the pan, so hopefully that will show me something.
