stumped!! #1605935
04/11/14 09:30 PM
04/11/14 09:30 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
hi guy's recently rebuilt my buddys 440. basic rebuild with ported 516s 509 cam etc... we got it all together went to fire it off for cam break in and it runs for bout 5mins and dies like someone turn the switch off. wont restart unles it sits for a few mins. any ideas changed coil carb is good n cool full of fuel 7psi fuel pressure. could the msd be takin a dump?
Re: stumped!! [Re: buck440] #1605936
04/11/14 10:44 PM
04/11/14 10:44 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Distributor pick-up coil? Sounds like something electrical is getting hot.
Good luck
Re: stumped!! [Re: buck440] #1605937
04/11/14 10:54 PM
04/11/14 10:54 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Ballast resistor
Re: stumped!! [Re: buck440] #1605938
04/12/14 08:42 AM
04/12/14 08:42 AM
gregsdart Offline
gregsdart  Offline
If it is a stock early wiring harness, it could be the wiring at the firewall feed through. Run a hot wire directly to your ignition for test.
Re: stumped!! [Re: gregsdart] #1605939
04/12/14 05:14 PM
04/12/14 05:14 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
ok guys update changed msd pickup cap rotor. started it ran for almost 4mins n shut down ? I believe its wired to the relay hot on the firewall or are you talkin bout the one to the ignition switch?
Re: stumped!! [Re: buck440] #1605940
04/12/14 05:39 PM
04/12/14 05:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
MSD says you should run the BIG red wire to the hot
battery... but I've never had any issue doing it to
the hot side of the relay... the small red goes to hot
ignition.... BUT since your having a problem run a
jumper from the hot battery to the big red just to
eliminate any possible issues... I would think more
like the dist pick up is bad.. so if you have another
dist try it... your having a thermo issue on the electronics
Re: stumped!! [Re: MR_P_BODY] #1605941
04/12/14 05:50 PM
04/12/14 05:50 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
that's what I was thinkin distrib. pick up was changed this morning does the msd 6al have thermal breakers in it? cause I give it five mins and bam it has fire again.
Re: stumped!! [Re: buck440] #1605942
04/12/14 06:01 PM
04/12/14 06:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know of any thermo switch in a 6al... you might
need to measure the voltage going to the MSD as soon
as it quits... both wires
EDIT
also check the ground when it quits
Re: stumped!! [Re: MR_P_BODY] #1605943
04/12/14 08:41 PM
04/12/14 08:41 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My big red and black both go to the battery.Rocky
Chrysler Firepower
Re: stumped!! [Re: therocks] #1605944
04/12/14 09:26 PM
04/12/14 09:26 PM
dogdays Offline
dogdays  Offline
So do mine. I think I used 12 gauge.
Looking into my used MSD6 before I installed it I didn't see anything that looks like a circuit breaker.
R.
Re: stumped!! [Re: dogdays] #1605945
04/13/14 01:48 AM
04/13/14 01:48 AM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
update new msd box runs like a champ just hope all the startin n stopping. didn't mess the 509 break in up that n rings n bearings!!
