1969 plymouth A/C #1605779
04/11/14 08:31 AM
04/11/14 08:31 AM
Woodbridge
Tommy The Chryco Offline OP
Woodbridge
does anyone have a supplier for a A/C heater core? thanks
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 1969 plymouth A/C [Re: Tommy The Chryco] #1605780
04/11/14 11:44 AM
04/11/14 11:44 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
If my memory serves me the place is called Classic Auto Air. I bought one for my 70 because OEM ones are impossible to find. They make one that is a copper tube and alum finned replacement. It is pricey but that is all we have. Buy a new mixing valve as well. They can leak, too. I may have a pic on the computer.
Re: 1969 plymouth A/C [Re: Tommy The Chryco] #1605781
04/11/14 12:29 PM
04/11/14 12:29 PM
New Berlin,Wi
Firepowerflyer Offline
New Berlin,Wi
Yes I also used Classic Auto Air on my 69 GTX.I sent them every piece of the ac system.Not cheap but it turned out nice I'm planning on charging it for the first time this spring.
Re: 1969 plymouth A/C [Re: fastmark] #1605782
04/12/14 09:04 AM
04/12/14 09:04 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
What are you talking about. They are all over the place. Including ebay...
http://www.ebay.com/itm/65-68-CHRYSLER-3...cfb&vxp=mtr
Re: 1969 plymouth A/C [Re: Commando1] #1605783
04/12/14 09:41 AM
04/12/14 09:41 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My point exactly. That is not an OEM heater core. That is the one that Classic auto Air repops. It is way more expensive than the original brass heater core.
Re: 1969 plymouth A/C [Re: fastmark] #1605784
04/12/14 08:27 PM
04/12/14 08:27 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
A few deades ago, if I needed a new heater core, a radiator shop would fabricate one exactly like the OEM using my original nozzles.
Might be able to do that nowadays if you can find a capable radiator shop run by an old timer.
Caveat: BE SURE to pressure test before you go to the trouble to re-install it! I had a few apparently pass the pressure test at the shop, then fail another test a few days later.
Re: 1969 plymouth A/C [Re: fastmark] #1605785
04/13/14 09:52 AM
04/13/14 09:52 AM
Commando1 Offline
Commando1  Offline
And my point is that it will be a lot cheaper than an original brass OEM heater core because you'll never find one.
Plus....
The OEM brass ones leaked given long enough. Like the aluminunum OEM REPLACMENT ones given long enough.
You won't own that car long enough.
Re: 1969 plymouth A/C [Re: Tommy The Chryco] #1605786
04/16/14 11:58 AM
04/16/14 11:58 AM
Wausau,Wisconsin
Kilrbee Offline
Kilrbee  Offline
Wausau,Wisconsin
Glen-Ray Radiators also recores the factory Heater and A/C heatercores!
Re: 1969 plymouth A/C [Re: Kilrbee] #1605787
04/17/14 12:32 PM
04/17/14 12:32 PM
Ohio
jimm69 Offline
jimm69  Offline
Ohio
I bought one from Year One. Expensive but no other alternatives. I still have my original if somone recores them. Not sure if it is good or not but wasnt going to take the chance after tearing apart the heater box and reinstalling it.
