How tight should injector fit? #1605560
04/10/14 07:58 PM
04/10/14 07:58 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
How tight in the fuel rail should an injector fit? The reason I ask I am using a set of custom rails that take a odd ball oring and the fit is "snug" but not tight like factory rails. I have never used anything but oem rails so is this normal or should I ditch these for a set that takes regular orings?
Re: How tight should injector fit? [Re: SLOW67] #1605561
04/10/14 08:17 PM
04/10/14 08:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you used Vaseline or another light grease they
slide in sorta easy... but they almost pop in
Re: How tight should injector fit? [Re: MR_P_BODY] #1605562
04/10/14 08:19 PM
04/10/14 08:19 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I used alittle vaseline on each one and they slid in real easy it just kinda made me wonder whether to try them or not
Re: How tight should injector fit? [Re: SLOW67] #1605563
04/10/14 08:24 PM
04/10/14 08:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If they were the thicker O-ring they do slip in a
bit easier (when greased)
Re: How tight should injector fit? [Re: MR_P_BODY] #1605564
04/10/14 10:42 PM
04/10/14 10:42 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
+1, when lubed, it should be fairly easy...
Just for the sake of locating parts easily, I'd prefer using the factory o-rings...but custom parts are cool...haha
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: How tight should injector fit? [Re: OUTLAWD] #1605565
04/11/14 12:20 AM
04/11/14 12:20 AM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Tried them out, they hold up to 50psi For some reason these rails were machined to take a 16.5mm o ring. I really don't understand why but the only orings that worked were from a 1983 Porsche 911 sc lol
