5.7 hemi #1605488
04/10/14 04:06 PM
04/10/14 04:06 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
I have a 07 Dodge Ram 2500 with a 5.7 hemi that is bone stock. What are some mods that you guys have done that will help with power and gas mileage? I avg. 12-14 mpg with just the truck and about 7 mpg when I tow my 24' enclosed trailer.
Re: 5.7 hemi [Re: DusterKid] #1605489
04/10/14 09:30 PM
04/10/14 09:30 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Had an 04 2500 off road that got the same mileage. It had 4.10 gears. Tried a cold air set-up (K&N FIPK) and put a free flow muffler on it. Niether made any significant difference. I traded it for a diesel.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 5.7 hemi [Re: DusterKid] #1605490
04/13/14 03:33 AM
04/13/14 03:33 AM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
I typed a long reply up and it "expired" when my attachment was too big.
Here is the short version.
4.56 gear swap for power (best mod for these IMO unless you already have a Power Wagon).
Free spin hub conversion for mileage (maybe one to two mpg and expensive, but also replaces the non-serviceable unit bearings).
Other common items are to fix the factory y-pipe which crushes the two sides in half. Replace with magnaflow. The best low $ mod.
Superchips for canned programming, Diablo for custom (IMO).
Header choice is limited on the 2500s (ARH and JBA). Research this carefully.
Cold air intakes on these do not tend to result in reports of much in the way of gains. Twenty plus pages on this at Dodgetalk.
Cam swap to a comp 260 also supposed to be worth decent power, and apparently will run on stock or canned programmer tunes, but better with custom. Lunati, Crower etc, and various "proprietary" grinds are also available.
Your mileage may vary.
Re: 5.7 hemi [Re: DusterKid] #1605491
04/14/14 01:19 PM
04/14/14 01:19 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Can't say for sure on the 5.7s, but I picked up 2mpgs and seat of the pants power with a high flow cat over the stock on.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
