Re: SS springs - orignal vs Made in Mexico [Re: BradH] #1605437
04/12/14 03:38 PM
04/12/14 03:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
... We don't run the bars just the springs...
I really believe that's the root of the issue. CalTrac's mono-leaf springs aren't there for any other purpose than setting the ride height of the car. All the load is supposed to be handled by the link system, not the springs.
The ones I have on The MoPig have shown no sag problems or any other issues. IMO, running them w/o the CalTrac bars is a misapplication of the mono-leaf springs.
Are you sure Brad?
Re: SS springs - orignal vs Made in Mexico [Re: Thumperdart] #1605438
04/12/14 04:43 PM
04/12/14 04:43 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I don't agree with you Brad. The springs should hold the car up.Many manufacturers have used monoleafs over the years. The Caltrac system was designed for NHRA Stockers. The mono leaf came a little later as I recall. The idea behind the monoleaf was to simply dump the unsprung weight. Early on caltracs were used on leaf springs. The job of the springs is to suspend the car. These springs do not do their job very long.
I will admit that I didn't think (especially for a stick car) that they were going to be any advantage other than the reduced weight. I figured they would wrap up uncontrollably. The autos were getting away with it so I figured I would try it. I talked to John Calvert about it and he made them how I wanted them. They had no down side the first year but during the second year the car got lower and lower and lower. I was happy to loose the weight and I could just replace the front segment. At the time I wanted to have them made with a 20 inch front segment and use a SS front hanger. Calvert advised against it but if I had to do it again that is what I would do. Would make the front segment stiffer.
Re: SS springs - orignal vs Made in Mexico [Re: scatpacktom] #1605439
04/12/14 04:54 PM
04/12/14 04:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
In less than 2 years the springs won't hold the car up. That has zippo to do with the "System". I'm not debating the Caltrac system... I am simply saying the quality of the spring steel sucks. Worn out in less than 20 races, who would be happy with that?
All the SS springs that I own that are ancient are the best. I had some newer XHD mopar springs on as well... They wear out very quickly too.
Maybe it's just me
It's not just you man
I took the "system" off my car after 2 sets of mono-leafs went completely flat after one season Now I must add that they worked great and my car hooked straight and true but I have better things to do than change my springs every year.
This was five years ago so they may have better springs now
Gus
64 Plymouth Savoy
Dana 60
Re: SS springs - orignal vs Made in Mexico [Re: fourgearsavoy] #1605440
04/12/14 09:39 PM
04/12/14 09:39 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I have been trying to get a real world answer for over a year on caltracs. This is the feedback that I suspeceted. Looks like super stock springs for me.
Re: SS springs - orignal vs Made in Mexico [Re: ccdave] #1605441
04/12/14 09:58 PM
04/12/14 09:58 PM
fullmetaljacket Offline
Mancini supposedly have their own version of the SS spring manufactured by a contracted company in Michigan. I believe they are called JRS.
I was told that they use better quality spring steel.
On the other hand, even though they're expensive, Landrum springs and or Tri-city springs have a some what better reputation for good springs. Tri-city's Launcher sets seem to be the best known.
I wish I could find an early set of SS springs made in Canada though.
Re: SS springs - orignal vs Made in Mexico [Re: Thumperdart] #1605442
04/12/14 10:06 PM
04/12/14 10:06 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I really believe that's the root of the issue...
Are you sure Brad?
That's my opinion, based on what I've both read and experienced with tuning leaf-spring suspension.
Re: SS springs - orignal vs Made in Mexico [Re: SSAAHemiFan] #1605443
04/12/14 10:18 PM
04/12/14 10:18 PM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
SS Mexico on the left ,Tri City on the right
Re: SS springs - orignal vs Made in Mexico [Re: scatpacktom] #1605444
04/12/14 10:18 PM
04/12/14 10:18 PM
BradH Offline
BradH  Offline
Not the first time I've heard that said!
Yes, and some of those are the first cars for which the Lakewood slapper bars were designed, IIRC. Lakewood used to run an ad talking about how "Grumpy" Jenkins designed their J-bar system that was supposed to be the hot lick for those early Camaro & Nova mono-leaf setups.
Yep, and when Calvert first used 'em on his 4-speed Super Stocker 428 CJ Mustang (that he still ran on 9" Stocker-size slicks) he used REALLY stiff multi-leaf springs w/o virtually no arch too.
I might still have the old SS&DI issue where they had a tech article on them when he first started using them and he went into the history & theory of the then-new bars.
As I recall, the switch to the mono was supposed to be both a weight reduction and a suspension reaction improvement.
I don't know if I have "good" springs and you and some others have "bad" springs, but mine have held up fine.
Re: SS springs - orignal vs Made in Mexico [Re: BradH] #1605445
04/13/14 12:26 AM
04/13/14 12:26 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
the issue is with the heat treatment..i bet...
if you find any diesel truck spring recon outfit.
you can send them your spings they will re arch and re heat treat them....i had a set on a duster done back in the 80s by a company in Pennsauken New Jersey they added and extra half a leaf to the front segment and re heat treated them..they lasted a long time..and ran high nines with a big block and a 4spd..and no added bars or links.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: SS springs - orignal vs Made in Mexico [Re: BradH] #1605446
04/13/14 12:32 AM
04/13/14 12:32 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Are you sure Brad?
It wasn`t directed towards you Brad................
Re: SS springs - orignal vs Made in Mexico [Re: Dartwizer] #1605447
04/16/14 11:30 PM
04/16/14 11:30 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The set on the right might as well be a solid bar.
Compressing stack and it will not return to the original height due to lack of sliding between the springs.
I've tried clamping springs. The are effective as intended. It strengthens the stack but lift it 2 inches, it will come back down only 1. Compress it 2 inches, it will only come back 1.
