help with a challenger column #1605218
04/09/14 02:19 PM
04/09/14 02:19 PM
Apollo, PA.
B1MAXX Online content OP
B1MAXX  Online Content OP
Apollo, PA.
I have 1970 challenger that didn't have the coupling fully slid down on the splines of the power steering gear, and the roll pin was in box that came with car. I removed the column from the car for engine compartment cleaning an painting. Now that I am ready to put it back together I have the column adjusted all the way forward (mtg bracket against the studs and the toe plate all the way back against the stop on the jacket) and it's still 3/8" short from fully engaging the steering gear splines. Any ideas or measurements you guys have would be greatly appreciated......
Re: help with a challenger column [Re: B1MAXX] #1605219
04/09/14 05:42 PM
04/09/14 05:42 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Any chance it could have been collapsed? Look in the parts book, and it will give the length that it should be. I just went through this. If you need any more help, PM me, and we can talk on the phone.
Re: help with a challenger column [Re: B1MAXX] #1605220
04/09/14 09:09 PM
04/09/14 09:09 PM
1970_EK2AAR Offline
1970_EK2AAR  Offline
A production length E body power steering shaft is 40.75 inches end-to-end. The length from the "splined" (steering wheel end) to the 3/16" machined adjustment hole is: 38.50". PM me if you need anything more.
Re: help with a challenger column [Re: 1970_EK2AAR] #1605221
04/10/14 12:20 AM
04/10/14 12:20 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The shaft are different lengths between manual steering and power steering. Do you have the right column?
Re: help with a challenger column [Re: B1MAXX] #1605222
04/10/14 11:31 AM
04/10/14 11:31 AM
pa.
dan9 Offline
dan9  Offline
pa.
Are the shoes in the coupler put in correctly?
Re: help with a challenger column [Re: 71birdJ68] #1605223
04/11/14 02:07 PM
04/11/14 02:07 PM
Apollo, PA.
Apollo, PA.
This is exactly what it was....
Re: help with a challenger column [Re: B1MAXX] #1605224
04/11/14 02:10 PM
04/11/14 02:10 PM
Apollo, PA.
Apollo, PA.
closer....should be 16.375"
Re: help with a challenger column [Re: B1MAXX] #1605225
04/11/14 05:58 PM
04/11/14 05:58 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I had to refix mine, I can tell you how to do if you want. PM me a phone number if you're in the US. Couple things I have found out.
Re: help with a challenger column [Re: 71birdJ68] #1605226
04/11/14 07:22 PM
04/11/14 07:22 PM
Apollo, PA.
Apollo, PA.
Thanks, but its already done .... Mine was still very hard to move but I followed the factory tech bulletin from Feb, 4 1970. I moved it out approx. 1" past 16.375, wire wheeled it, applied epoxy and moved it back to 16.375. My guess is someone beat the wheel off instead of properly pulling it.
Re: help with a challenger column [Re: B1MAXX] #1605227
04/12/14 08:58 AM
04/12/14 08:58 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Could you post that service bulletin please? I got mine fixed, but would like a copy of the bulletin.
Re: help with a challenger column [Re: 71birdJ68] #1605228
04/12/14 11:46 AM
04/12/14 11:46 AM
Apollo, PA.
Apollo, PA.
Re: help with a challenger column [Re: B1MAXX] #1605229
04/12/14 05:39 PM
04/12/14 05:39 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Thanks, what I did was clean out the old plastic, and and forced hot glue back into the same place with a hot glue gun.
Re: help with a challenger column [Re: 71birdJ68] #1605230
04/15/14 07:51 AM
04/15/14 07:51 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What kind of expo did you use?
Re: help with a challenger column [Re: 71birdJ68] #1605231
04/15/14 02:17 PM
04/15/14 02:17 PM
Apollo, PA.
Apollo, PA.
J-B
Re: help with a challenger column [Re: B1MAXX] #1605232
07/08/14 10:14 AM
07/08/14 10:14 AM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
Does anyone know if the length of the challenger and cuda shafts are the same?
Jason
