Cylinder Hone Grit #1605138
04/09/14 02:42 AM
04/09/14 02:42 AM
Chester, VA
tobnHisglory Offline OP
Chester, VA
I am putting together a 440 with Mahle file fit plasma moly rings. My questioin is what would you guys recommend for the cylinder hone. I have a access to 320, 400, and 800 grit flex hones. I was under the impression that smoother was better with plasma moly because you don't need the "roughness" to hold oil on the cylinder wall like you do with cheaper rings. What would you guys suggest?
Thanks in advance!
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: Cylinder Hone Grit [Re: tobnHisglory] #1605139
04/09/14 10:21 AM
04/09/14 10:21 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
320
Re: Cylinder Hone Grit [Re: BradH] #1605140
04/09/14 12:13 PM
04/09/14 12:13 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Re: Cylinder Hone Grit [Re: RemCharger] #1605141
04/09/14 01:48 PM
04/09/14 01:48 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It's a combination of rough and fine with a plateau finish that works best. If what you have is no longer good enough due to wear I'd have it done professionally. 320 is way too rough for a bore finish. Just run iron rings and prepare to break it in because the moly will simply be torn off the rings.
Re: Cylinder Hone Grit [Re: moper] #1605142
04/09/14 01:52 PM
04/09/14 01:52 PM
dogdays Offline
dogdays  Offline
What does Mahle say? They'd be the experts on their own rings.
R.
Re: Cylinder Hone Grit [Re: dogdays] #1605143
04/09/14 04:42 PM
04/09/14 04:42 PM
Chester, VA
Chester, VA
I called Mahle ' s tech line and they said they have seen no significant difference in seal or longevity within the 320 to 800 range. They said to ask my preferred builder for their recommendation. I am assembling this motor as well as one for a friend and plan to buy my own hone from the 3 new ones available to me listed above so hone wear is not an issue at this point.
Thanks for the comments!
-Reggie
Re: Cylinder Hone Grit [Re: BradH] #1605144
04/09/14 06:04 PM
04/09/14 06:04 PM
BradH Offline
BradH  Offline
Correction: 320 + a plateau brush finish, per the guy that's done my last two blocks.
Re: Cylinder Hone Grit [Re: BradH] #1605145
04/09/14 10:04 PM
04/09/14 10:04 PM
Chester, VA
Chester, VA
Good info BradH, but can you elaborate on the plateau finish? I thought that was what the flex hone created. Do I need a different finishing brush after the hone or does he mean to start with a 320 hone and then finish with a finer hone?
Thanks so much for the help!
-Reggie
Re: Cylinder Hone Grit [Re: tobnHisglory] #1605146
04/09/14 11:20 PM
04/09/14 11:20 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
A plateau finish takes off the high spots created by the original honing stones. That portion is normally taken off by the rings, hence the break in period. Without removing this high surface you risk ruining the moly surface. And to make matters worse, it almost always needs to be done properly with a machine that can control the pressure and stroke of the stone.
Re: Cylinder Hone Grit [Re: drew72] #1605147
04/10/14 01:04 AM
04/10/14 01:04 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
320....just run it forward and reverse...If it makes you feel better about it a Scotchbrite finisher will knock off the "high" spots...then you can brag up your "plateau" finish. Way more important is to make sure the bores are squeaky clean when finished.....
Re: Cylinder Hone Grit [Re: Bill MeLater] #1605148
04/10/14 03:03 PM
04/10/14 03:03 PM
dogdays Offline
dogdays  Offline
NO. To be specific, the words "plateau" and "Brush" are associated with Brush hones.
What was meant by what the machinist said was to finish hone with 320, then run a Brush ball hone through the hole to produce the plateaued surface.
Go to http://www.brushresearch.com/literature.php?type=2 and read the tech articles and you'll see what I mean.
R.
Re: Cylinder Hone Grit [Re: dogdays] #1605149
04/10/14 04:01 PM
04/10/14 04:01 PM
Chester, VA
Chester, VA
Thanks for the clarity. I already had it machine honed at the shop to the proper bore with (I believe) 320 stones. I was going to finish it with a ball hone myself. I think I was doing what you suggest I just wasn't using the terms properly. That being said, I think I'll use the 800 for the plateau finish over what the machine shop did.
Thanks again for all the replies!
-Reggie
Re: Cylinder Hone Grit [Re: dogdays] #1605150
04/10/14 09:26 PM
04/10/14 09:26 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
R.
No, a plateau finish is NOT necessarily associated with a dingleberry or ball hone. If you want a proper finish you use the special Sunnen plateau stones in a Sunnen machine. It can be done the other way but is far inferior. Sorry, been doing it for a living for almost 25 years.
Re: Cylinder Hone Grit [Re: tobnHisglory] #1605151
04/11/14 01:57 PM
04/11/14 01:57 PM
ohio
prochamp Offline
prochamp  Offline
ohio
i manage a machine shop and machine blocks for a living as well.if your machine shop finished the bores to size properly you shouln't touch it other than to clean it before assembly.it sounds like your not sure what they did? i suggest that you give them a call and go over it with them before ruining some potentially good,finished work.
