Cone Sure Grip case bolts torque
#1605053
04/08/14 11:31 PM
04/08/14 11:31 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
Hey guys! Ive been reading up on "rebuilding" cone type Sure Grips. I have a used one that I just purchased and am ready to disassemble and inspect, but I am not sure what the torque spec on the case bolts are when I go to re-assemble it. Anybody got the torque number handy? Is there an official spec, or is "tight" the answer? Thanks!
Paul '69 Super Bee 383 EFI Turbo
Re: Cone Sure Grip case bolts torque
[Re: dogdays]
#1605055
04/09/14 02:03 PM
04/09/14 02:03 PM
Black_Bee
BC, Canada
What size and grade are the bolts? Add 2 to the number of tick marks on the bolt head and you'll get the grade. I bet they're Grade 8, meaning 6 tick marks. Bolts are sized to be tightened to 75-80% of their yield strength. That's a standard design practice. So you won't for example, find a 1/2" bolt with specified torque 45 lb-ft. Well, you actually might, but absent the tightening specification, it's safe for the bolt to be torqued to 75-80% of its yield strength. There are charts all over the internet.
R.
Thanks for the advice!
I've been looking on the net, and have found a few pages with some advice for roughly determining unknown torque specs such as marking the bolt orientation, backing it off and then torquing till the marks have lined up.
Im sure I just need to be in the ballpark really
Thanks again!
[Re: dogdays]
#1605057
04/09/14 07:54 PM
04/09/14 07:54 PM
Black_Bee
BC, Canada
Don't you have a torque wrench? Even a Harbor Freight one is better than guesswork.
Why can't you measure the bolt diameter?
Did you really want an answer to your question, or did you ask so you could say "my guess is close enough"?
R.
I do have a torque wrench (the original post was asking for a factory torque spec after all ) and calipers to measure.
I am not an engineer, so I was just mentioning another method that I found on the Internet (it does involve using a torque wrench), but based on your response it sounds like it couldn't work here.
As you suggested, I will check the grade and measure the bolt. Then subtract a certain percentage of the yield strength. Hey, that still sounds like a ballpark number to me!
Thanks again, I do appreciate your help here!
[Re: 1969ronnie]
#1605059
04/10/14 12:10 PM
04/10/14 12:10 PM
Black_Bee
BC, Canada
hi, there are 2 sizes of case bolts used. 3/8 bolts or 5/16 and they take different torque specs.
Are you saying that there are 2 sizes in the same case, or a case will have one of those 2 sizes?
I pulled and measured a bolt last night,,, 3/8" grade 8. According to a bunch of engineering and bolt related websites, the torque for that bolt is anywhere from 22-35 ft-lbs lubed to 35-50 ft-lbs dry.
Should i just pick a number in that range and go with it?
[Re: mopowers]
#1605061
04/10/14 02:57 PM
04/10/14 02:57 PM
dogdays
I like this chart from Portland Bolt: http://www.portlandbolt.com/technicalinformation/bolt-torque-chart.htmlTo read up on the subject of bolted joints, Fastenal which is a major bolt manufacturer, has a technical manual you can download. Some of it is pretty heavy going, but it is accurate which is important. For your 3/8" capscrews, which is what I think they are, I'd use the values 44 lb-ft for coarse threads and 47 lb-ft for fine threads. I'd torque them dry, because the values above are for dry threads. Properly torqued, they should not need any kind of threadlocker. Torquing is a rather poor way of measuring clamping force, which is what one wants to set. But, measuring bolt length is pretty hard in many instances. There are theory-derived formulas for equating bolt torque and clamping force, but they are modified by empirically-derived factors for friction. This is why ARP is very specific about burnishing threads and using its proprietary lube on the threads. This can take most of the guesswork out. If you understand this, you can see why auto manufacturers are migrating to torque-to-yield bolts in critical applications. For your application, the values I gave are current design standard numbers. R.
[Re: dogdays]
#1605062
04/10/14 03:04 PM
04/10/14 03:04 PM
Black_Bee
BC, Canada
R.
Thanks!
I hate to keep dragging on a topic, but is there any reason why I shouldn't use the lubricated spec of 22 ft-lbs from the Portland Bolt link?
Thanks again, for sticking with me, and helping out!
[Re: Black_Bee]
#1605063
04/10/14 04:07 PM
04/10/14 04:07 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Dana 60 Sure grips had a torque spec of 35-45 per the FSM. I believe they are the same size bolts. Nice wide range, crazy. You aren't building a space shuttle... I'd torque them to 40ish# and get done with it. Feel can also play a big part in setting them up. Maybe ask Cass, except he's probably at MATS this weekend.
