7 or 8 quart oil pan for my Big Block? #160496
12/03/08 02:50 PM
12/03/08 02:50 PM
Anonymous OP
Anonymous OP
I only want to buy a pan once, is the 8 quart really needed. This is a 10.5 to 1 engine, 451, driver and maybe a little 1/4 mile, engine has seen 7000 rpm in the past. What are your thoughts?
Thanks in advance!
Tim
Re: 7 or 8 quart oil pan for my Big Block? #160497
12/03/08 05:17 PM
12/03/08 05:17 PM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
I have a 7 qt on my 451 like yours, I should have got a windage tray too, That is going in this winter. Do both at the same time.
Re: 7 or 8 quart oil pan for my Big Block? [Re: DAMOPARS] #160498
12/04/08 10:11 AM
12/04/08 10:11 AM
Anonymous OP
Anonymous OP
I have heard mixed reviews on putting a windage tray on as far as horsepower. Is it worth the extra $?
Re: 7 or 8 quart oil pan for my Big Block? #160499
12/04/08 03:49 PM
12/04/08 03:49 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
If you're planning on getting a Mildon pan, be prepared to wait. I've got on on order, was originally told 4-6 weeks, it has now been delayed twice and will end up about a 2.5 month wait -- if it shows up next Monday (and I'm not holding my breath).
I don't know if this is typical for them, but regardless, my only experience with them has earned them an F- in my book.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: 7 or 8 quart oil pan for my Big Block? #160500
12/04/08 07:50 PM
12/04/08 07:50 PM
tucson az
frank Offline
frank  Offline
tucson az
According to the old Mopar Performance engine bulletins it is worth extra HP at higher RPM's. I don't remember how much.
Re: 7 or 8 quart oil pan for my Big Block? [Re: frank] #160501
12/04/08 07:54 PM
12/04/08 07:54 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I bought one here got it in 2 days
http://dieselgalaxy.com/product.php?productid=74673
Re: 7 or 8 quart oil pan for my Big Block? #160502
12/05/08 12:18 AM
12/05/08 12:18 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
A 7 quart pan should be just fine. Check out the Milodon road race pan #31580, it holds 7qts but doesn't hang as low as the drag pans. http://www.milodon.com/oil-pans/road-race-oil-pans.asp
Re: 7 or 8 quart oil pan for my Big Block? [Re: Azzkikrcuda] #160503
12/05/08 02:09 AM
12/05/08 02:09 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use this Moroso 8 qt pan. I drive it on the street all the time and the pan has plenty of road clearence. Ron
Re: 7 or 8 quart oil pan for my Big Block? [Re: Fury Fan] #160504
12/05/08 02:39 AM
12/05/08 02:39 AM
Vancouver BC Canada
N
nike_hockey85 Offline
N
Vancouver BC Canada
Haha yeah I just ordered a one of the same oil pans and went with a 7 qrt and waited for a month or so. I go the windage tray and pickup as well. Not sure on how its going to fit as I just got it last week and the motor is being built next weel!
Re: 7 or 8 quart oil pan for my Big Block? [Re: nike_hockey85] #160505
12/05/08 02:40 AM
12/05/08 02:40 AM
Vancouver BC Canada
N
N
Vancouver BC Canada
haha week sorry!
Re: 7 or 8 quart oil pan for my Big Block? [Re: Azzkikrcuda] #160506
12/05/08 09:02 AM
12/05/08 09:02 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
That's the same pan I'm waiting on! Looks like a great design, but of course I've yet to lay my hands on it...
Re: 7 or 8 quart oil pan for my Big Block? [Re: Fury Fan] #160507
12/05/08 09:41 AM
12/05/08 09:41 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Personally,if you are doing only a limited amount of racing I would use the Mopar Perf replacement Hemi / 6pk pan,you will have all the oil you need and still looks stock.Here is an original Max Wedge pan,they were not run on the street.Guess how much it holds.
Re: 7 or 8 quart oil pan for my Big Block? [Re: 62maxwgn] #160508
12/05/08 02:58 PM
12/05/08 02:58 PM
Anonymous OP
Anonymous OP
The pan I was looking at was from 440Source, 7 quart and $80. Anybody use that pan?
Re: 7 or 8 quart oil pan for my Big Block? #160509
12/05/08 05:40 PM
12/05/08 05:40 PM
Huntington, WV
MoparMe70 Offline
MoparMe70  Offline
Huntington, WV
Re: 7 or 8 quart oil pan for my Big Block? [Re: 62maxwgn] #160510
12/05/08 08:40 PM
12/05/08 08:40 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Bill, I'll guess 7... ..Looks like an extra quart over the hemi pan...
Re: 7 or 8 quart oil pan for my Big Block? [Re: screamindriver] #160511
12/05/08 09:12 PM
12/05/08 09:12 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Try 6gt,7 with filter.
Re: 7 or 8 quart oil pan for my Big Block? #160512
12/06/08 03:51 AM
12/06/08 03:51 AM
Vancouver BC Canada
N
N
Vancouver BC Canada
Ok well I just went to go drop off some parts for my 440 thats getting built and we opened the miloden box to look at the new 7 qrt oil pan, windage tray and pickup. But they must have a different style oil dipstick tube as its threaded into the oil pan it looks like. I dont have the old stock oil pan but the dipstick I got is just a push in type not threaded. anyone run into this problem and if so know where to get the right dipstick!?
Re: 7 or 8 quart oil pan for my Big Block? [Re: nike_hockey85] #160513
12/06/08 11:17 AM
12/06/08 11:17 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Sounds like either you got a truck pan, or the piece got goofed up.
Re: 7 or 8 quart oil pan for my Big Block? [Re: ZIPPY] #160514
12/06/08 01:54 PM
12/06/08 01:54 PM
Vancouver BC Canada
N
N
Vancouver BC Canada
oh... are the truck pans different from the car ones or somthing? I beleive it probably is a truck pan, its rear sump. But didnt know there was different dipstick tubes.
Re: 7 or 8 quart oil pan for my Big Block? #160515
12/06/08 02:21 PM
12/06/08 02:21 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Im running the Source pan in my 67 383 Satellite. I run it with a MP windage tray. It hangs pretty low, but I've never had a problem. The only thing I can think of is perhaps the more expensive pans are made of thicker guage steel (???), other than that, I don't see the need to spend a bunch of extra money on an oil pan. I think you're just paying for all the advertising and stickers that Milodon puts out.
