97 Dodge Truck trans #1604463
04/07/14 06:49 PM
04/07/14 06:49 PM
Pottstown, Pa.
sg1093 Offline OP
sg1093  Offline OP
Pottstown, Pa.
I have a 1997 Dodge Ram 2500 , 5.9L gas engine, auto trans, 4x4 . The transmission will not upshift all the time. I have a 99 Dodge Durango, 5.9L gas engine, auto, 4x4 that is wrecked. Will the Durango trans work in the Ram ?
Re: 97 Dodge Truck trans [Re: sg1093] #1604464
04/07/14 07:47 PM
04/07/14 07:47 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Replace the governor solenoid & transducer before you change trans to see if that solves your problem.
Re: 97 Dodge Truck trans [Re: redraptor] #1604465
04/08/14 06:27 PM
04/08/14 06:27 PM
Pottstown, Pa.
sg1093 Offline OP
sg1093  Offline OP
Pottstown, Pa.
I have replaced two solenoids inside the trans previously, and bypassed the cooler lines with no difference. So I have to rebuild the truck trans or swap it out.
Re: 97 Dodge Truck trans [Re: sg1093] #1604466
04/08/14 09:58 PM
04/08/14 09:58 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The bellhousing is a little different on the lower drivers side but should work. There will be some bolt holes unused from where the bracketry on the Durango mount the trans to the front diff and engine. If you were putting the truck trans in the durango it might be an issue.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 97 Dodge Truck trans [Re: 71yelladustr] #1604467
04/10/14 12:15 AM
04/10/14 12:15 AM
Pottstown, Pa.
sg1093 Offline OP
sg1093  Offline OP
Pottstown, Pa.
Thank you.
