Re: Looking for Sand Casting company - any recommendation?
[Re: MCTPhoenix]
#1604437
04/07/14 08:33 PM
04/07/14 08:33 PM
Posts: 15,802 Jefferson State
srt
ESYC
ESYC
Jefferson State
terminal brass and aluminum foundry in south san francisco. I think he can still get patterns made as well. I first found used them in the early 80's for small one-off pieces, they didn't like making patterns then, but I had a guy. I think they now have one working in house, I could check, but I suggest you give Wayne a call and talk with him.
[Re: srt]
#1604439
04/07/14 10:18 PM
04/07/14 10:18 PM
Posts: 294 Phoenix, AZ
MCTPhoenix
Phoenix, AZ
By making patterns do you mean making a mold from scratch (design) or them using my part to create a mold to make more parts?
[Re: 340duster340]
#1604440
04/07/14 10:21 PM
04/07/14 10:21 PM
MCTPhoenix
Phoenix, AZ
find a good product development firm, have them 3d scan it, or render the part by hand, take the CAD file and shop bids from MFG.com (globally)
I know so little about this. So do I google 3D scan or something and hire a company to do that? I thought that leads to the expensive $30-$50K type of mold I'm not looking for?
[Re: MCTPhoenix]
#1604441
04/07/14 10:58 PM
04/07/14 10:58 PM
Posts: 4,323 NY NY
340duster340
NY NY
i used to do the 3D rendering, i never had experience with 3d scanning, but what either will give you is a 3D drawing of your part that manufacturers can uses to figure out how they will make your part. you need to specify material and process but the CAD file format can be interpreted by them to have all the dimensions, etc. i am not familiar with pricing for this type of service, but here is a company that came up on the google search...prices seem reasonable ( a few hundred). http://www.3dscanservices.com/samples2.aspxonce you have the cad file, you can shop it for quote on manufacture, or better yet ask the scanner guys what to do, they are definitely more up-to-date than i am! you might need to pay more if you need them to clean up the image, but still seems cheap
[Re: srt]
#1604443
04/08/14 07:55 AM
04/08/14 07:55 AM
Posts: 75 Lakeland, FL
sixpakchallenger
Lakeland, FL
The first thing you need is a CAD model of the part you want to make. After you have the model you can talk to a sand casting house. Depending on the number of parts, you can either have the parts run "loose", or have a match plate made. Running loose limits you to about 10 parts. Match plate will give you hundreds of parts. Review these pages: http://www.foundry.ray-vin.com/matchplate/matchplate.htmhttp://thelibraryofmanufacturing.com/metalcasting_sand.htmlI could be more helpful if I knew what part you want to make and the alloy. I deal with low volume sand castings daily and I typically 3D print the master and supply to the casting house, or print the splits to be made into the match plate. We use 356-T6
2007 Mustang GT Vert 2004 Ram 2500 QC 4X4 1971 Challenger Vert 5.7 Hemi Project
[Re: MCTPhoenix]
#1604445
04/08/14 04:08 PM
04/08/14 04:08 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
??? Aren't the recall wheels already being reproduced? Seems to me you'd be reinventing the wheel - no pun intended! Since you're dealing with aluminum you can't just make a mold from the original as you have to account for the shrinkage of aluminum - which is significant. The ideal way in this day and age of modern technology would be to determine the shrink factor and have someone do a cad program of the desired item taking that shrink factor into account. Then have the item made on a 3D printer and then use that to make the mold. See shrink factors here: http://www.shelmetcastings.com/shrinkage-allowance-for-metal-casting.htmlSince these guys also claim to be "short run experts" they me be who you want to talk to. I have no idea - I just googled "shrink factor" and they popped up!
[Re: Stanton]
#1604451
04/09/14 02:10 AM
04/09/14 02:10 AM
Posts: 237 USA
Grizzly69
USA
But you can't reproduce the cast finish with billet. No doubt billet would be the way to go if it were an option.
The "cast" finish on the recall wheels is...
Paint.
[Re: Stanton]
#1604455
04/09/14 09:38 AM
04/09/14 09:38 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
But a single billet could be painted and finished correctly to reproduce an as-cast surface, accounting for the shrinkage factor, and a mold made out of that.
