Re: Water Temp Fitting?
[Re: RapidRobert]
#1604424
04/07/14 08:42 PM
04/07/14 08:42 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Do they sell a pipe fitting that adapts the threads from the larger sending unit to the smaller intake hole, or is it best to drill and tap the intake for the larger 1/2" NPT sending unit?
(1) yes (2) maybe. Someone brought up something priorly about the sender needs a certain amount of depth into the coolant to register properly. I ain't sure if that is valid or not but you might see what others have to say and call Autometer. Is the boss on the intake large enough to go out to 1/2NPT?
Probe should fit so that it is in the flow of the coolant for most consistent accurate readings.If using to many fitting and getting it out of the flow there a chance of air pockets and slower moving coolant than in the main flow.
[Re: forphorty]
#1604426
04/07/14 10:00 PM
04/07/14 10:00 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Most probes are too deep to fit by just tapping the hole.The fitting that adapts it has a recess inside so the bulb seals.Some cheap gauges have them with them.We got ours at Advanced.IIRC they were like 3 or 4 bucks.The parts guy might have to look for it though.I have good parts guys.Rocky
Chrysler Firepower
[Re: therocks]
#1604427
04/07/14 10:36 PM
04/07/14 10:36 PM
Posts: 62 montreal, quebec,canada
7e5dartsport
to solve the depth problem, use autometer 2271. it is a 3/8 npt extension. 2270 for 1/2 npt. to make it fit to your intake, napa or others will have what you need, just bring your intake and extension so they can choose the correct adaptor for you. hope this helps.
fully legal sounds the same as full illegal...
[Re: RapidRobert]
#1604428
04/08/14 01:41 PM
04/08/14 01:41 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Thanks for the input guys. The boss is plenty large to drill and tap. I may just go that route. Here is a picture of the old intake Here is the new one with the under-sized hole just left of the water neck: Should the fittings go like this?: Or like this?
[Re: skicker]
#1604430
04/09/14 01:04 PM
04/09/14 01:04 PM
mopowers
Sac, CA
Put the new temp gauge fitting in the drivers side and use the nipple in the hole on the passenger side. You don't want to look at the heater hose crossing the upper radiator hose.
That's kinda what I was thinking. Thanks a lot.
