Re: 915 and 516 CC's [Re: Sport440] #1604300
04/09/14 12:11 AM
04/09/14 12:11 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
How much do you think the seat and valve combined are ground on a wore out set of heads?
Re: 915 and 516 CC's [Re: BSB67] #1604301
04/09/14 12:55 AM
04/09/14 12:55 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not "Wore out", Just a valve job like you stated.
Back at you. How much do you think the seat and the valve combined are ground on Just a valve job?
Between the two, if its just a valve job as little as .010 maybe .020 if its surfaces are worn.
Not anywhere close to the .250 x.980 sloped .000 to .250 x 4.08 divot combined surface area of my valve reliefs that equates to 5cc in my KB 237,s
Valve job = touch the seat and the valve. .2cc
Valve reliefs = Big .250 x .980 x 4.08 Slanted gutter. 5cc
Re: 915 and 516 CC's [Re: BSB67] #1604302
04/09/14 03:12 AM
04/09/14 03:12 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
My 67 440 has never been decked and I'm getting .065 -.070 on all cylinders.
Re: 915 and 516 CC's [Re: Sport440] #1604303
04/09/14 08:34 AM
04/09/14 08:34 AM
Prospect, PA
Prospect, PA
One of us is doing the math wrong. I too would guess 0.010" to 0.020"
0.020" drop of both valves is almost 2 cc. If my math is wrong, please let me know.
Surface area of the entire valve verses the notch is not a good comparison.
My point is that if someone is getting 84 cc on a set of 915s, it might be be that it has had one or two NAPA valve grinds. Maybe just factory variability...I don't know
Re: 915 and 516 CC's [Re: elmor353] #1604304
04/09/14 11:53 AM
04/09/14 11:53 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Can anyone tell me how many cc's the combustion chambers are on these heads?
The sets I've measured were between 80-82 cc
Re: 915 and 516 CC's [Re: BSB67] #1604305
04/09/14 01:50 PM
04/09/14 01:50 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
No your Math is correct, decided to check it myself instead of guesstimate.
At 0.010 on both a 2.14 and 1.81 valve = 1.011 cc
At 0.020 on both double that = 2.022 cc
My eyeball measurement wasnt very correct
Thanks for the correction
Re: 915 and 516 CC's [Re: Sport440] #1604306
04/09/14 07:53 PM
04/09/14 07:53 PM
Prospect, PA
Prospect, PA
I used 2.08 and 1.74 as we are talking about factory heads so my numbers are a bit less. I too was a little surprised at the magnitude of the volume change with small changes in the valve depth.
