Re: 12 v on 7 way trailer plug
[Re: duster408]
#1604068
04/07/14 03:49 AM
04/07/14 03:49 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
If you are checking with the engine off, you will find that it is probably only hot when the engine is running...that is if we are talking about a factory installed tow package. The 7 way plug is a "RV plug" and is designed to keep the trailer batteries charged while towing, that would include the house batteries on a travel trailer and the breakaway battery on a car trailer.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: duster408]
#1604069
04/07/14 12:09 PM
04/07/14 12:09 PM
Challenger 1
Cincinnati, Ohio
To energize it you must install the large 30 amp fuse and connect it up to the fuse box under the hood. It's not connected from the factory.
The fuse and a pigtail for the brake controller should be in a bag in the glove compartment.
