12 v on 7 way trailer plug #1604066
04/06/14 07:17 PM
04/06/14 07:17 PM
duster408 Offline OP
Does anyone know how to get 12v to the 7 way plug on a 2013 Ram 2500, I have looked for a fuse and I can't seem to find one missing
Re: 12 v on 7 way trailer plug [Re: duster408] #1604067
04/06/14 10:57 PM
04/06/14 10:57 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Maybe the fuse is blown? Look in your owners manual it should tell you.
Re: 12 v on 7 way trailer plug [Re: duster408] #1604068
04/07/14 03:49 AM
04/07/14 03:49 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
If you are checking with the engine off, you will find that it is probably only hot when the engine is running...that is if we are talking about a factory installed tow package. The 7 way plug is a "RV plug" and is designed to keep the trailer batteries charged while towing, that would include the house batteries on a travel trailer and the breakaway battery on a car trailer.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 12 v on 7 way trailer plug [Re: duster408] #1604069
04/07/14 12:09 PM
04/07/14 12:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
To energize it you must install the large 30 amp fuse and connect it up to the fuse box under the hood. It's not connected from the factory.
The fuse and a pigtail for the brake controller should be in a bag in the glove compartment.
