Interiror Rear Window trim install Charger #1604060
04/06/14 06:50 PM
04/06/14 06:50 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
How does the interior rear window trim install on a the 68-70 Chargers?
Does the channel on the trim fit into the thin metal frame above where the teeth are ( where the headliner attaches to) or into the teeth where the headliner is installed?
Re: Interiror Rear Window trim install Charger [Re: MONC] #1604061
04/06/14 07:27 PM
04/06/14 07:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Does the channel on the trim fit into the metal frame above where the teeth are ( where the vinyl top attached to) or into the teeth where the vinyl top is installed?
It's been awhile since I've done a Charger headliner, IIRC it installs on the teeth to dress the edge, only the lower center piece installs on a metal channel IIRC
Mike
Re: Interiror Rear Window trim install Charger [Re: DAYCLONA] #1604062
04/07/14 09:35 AM
04/07/14 09:35 AM
MONC Offline OP
MONC  Offline OP
I edited the post I meant to say headliner not vinyl top.
That's what I get for making a post when having a migraine.
Ok, thanks Mike
The original lower piece was already there. I probably would have been even more confused, had I seen it installed on the metal channel, and figured they all must go that way.
I'll try again on the weekend, hopefully with a clearer head ...
